Old 12-09-2016, 07:10 PM   #1
Dustmaker65
Dustmaker65's Avatar
Anyone using stock radiator on LS swap?
As title states...anyone using stock 67-72 radiator on their LS swap?
If so, what fan you using?
what hoses are you using?
what shroud you using?
Thanks!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 12-09-2016, 07:26 PM   #2
68basket
Re: Anyone using stock radiator on LS swap?
Thanks!
yes ive used a stock radiator. Upper hose from any of the chevy trucks like a 2004 tahoe. lower hose from same vehicle if i remember correctly.
I used an electric fan from a ford taurus.
68basket is offline   Reply With Quote
Old 12-09-2016, 08:21 PM   #3
dayj1
Thanks!
I used a stock radiator. Details here: http://67-72chevytrucks.com/vboard/s...69&postcount=6
dayj1 is offline   Reply With Quote
Old 12-09-2016, 09:29 PM   #4
Kennuck
Kennuck's Avatar
I used the stock rad, engine driven fan, stock small block shroud.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 12-10-2016, 09:27 PM   #5
Willie Makeit
Willie Makeit's Avatar
stock 4 row with dual Spal fans and a custome made shroud that also houses my intercooler heat exchanger.
Willie Makeit is offline   Reply With Quote
Old 12-11-2016, 11:01 PM   #6
Dustmaker65
Thanks guys!!!
Jimmy Hoelzel
Old 12-12-2016, 08:22 AM   #7
Gipper01
Gipper01's Avatar
I'm running a stock 4 core radiator with a 2008 5.3l swap with dual dodge Stratus fans from the JY. It took a little work figuring out the right thermostat (180 degree) but the combination is doing VERY well.
Gipper01 is offline   Reply With Quote
