Old 11-21-2016, 01:52 PM   #1
jamesrussell26
shift linkage for 4l60e
ok i have tried the search function and all i seem to get is ads for buying new parts. i have a 66 c10 with factory auto column and a 2007 4.8 and 4l60e i need to connect the column to the trans any post out there that have done this? i refuse to use a floor shift so no need to even mention them.i was thining a cable like factory 07 used and a couple brackets. but i have seen linkage rod kits. i know someone has done this at some point. help please
jamesrussell26 is offline   Reply With Quote
Old 11-21-2016, 02:31 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: shift linkage for 4l60e
Lokar
Hart_Rod is offline   Reply With Quote
Old 11-21-2016, 06:39 PM   #3
68c10airstream
68c10airstream's Avatar
i used the stock rod down to the side of the frame and then from there i went to the salvage yard and grabbed a few bell cranks as fab stock to make what i want. Purchased from gm a new white plastic cup for the frame mount pocket and then worked with factory manual lever that attaches on the trans. I would tack weld up various layouts untill i had full travel into manual low and all detents work. Took some time but works nice.
A shift cable will probably be easier. If gm used it on a truck with a od trans i would try that. Good luck.
68c10airstream is offline   Reply With Quote
Old 11-21-2016, 10:09 PM   #4
jessemthompson
Originally Posted by Hart_Rod View Post
Lokar
I'll second for Lokar.
jessemthompson is offline   Reply With Quote
Old 12-05-2016, 03:09 PM   #5
jamesrussell26
just an update.... snagged an OE cable from a 2004 tahoe attached on trans side with factory bracket. turned the pivot point on column around facing firewall attached cable built a bracket for the cable mount bolted to inner fender. works well so far and i have about 4 dollars in the project
Old 12-12-2016, 08:29 AM   #6
Gipper01
Gipper01's Avatar
Ditto on Hart Rods recommendation (Lokar). Just make sure to be patient with the install. I jacked up my first install by cutting the rod to short-couldn't get the shifter to 1st gear. Measure 4 times cut once.
Gipper01 is offline   Reply With Quote
Old 12-12-2016, 01:02 PM   #7
Willie Makeit
Willie Makeit's Avatar
lokar user here too
Willie Makeit is offline   Reply With Quote
Old 12-12-2016, 02:08 PM   #8
Hart_Rod
Hart_Rod's Avatar
FYI, You can buy the rod by itself if you need a new one.
Old 12-12-2016, 10:08 PM   #9
Gipper01
Gipper01's Avatar
That's exactly what I did Hart Rod. Install pending warmer weather.
Old 12-13-2016, 02:09 PM   #10
geekitupsum
lokar universal shift linkage here as well
geekitupsum is offline   Reply With Quote
