Old 12-08-2016, 03:51 PM   #1
chiefcfd
chiefcfd's Avatar
Fuel from rear tank
I installed a Blazer tank in the rear. Manual fuel pump to a 600 Edelbrock carb. My problem is that after sitting for a few days it appears the fuel line is running dry. It takes lots of cranking to get to fire up. Anyone else notice this? I have thought about some sort of one way valve to install inline.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 12-08-2016, 07:46 PM   #2
custom10nut
custom10nut's Avatar
Re: Fuel from rear tank
Very good question. I'm about to do the tank relocation, and never thought about that.
Was this an inherent problem with the Balzers and Suburbans?
custom10nut is offline   Reply With Quote
Old 12-10-2016, 10:45 PM   #3
chiefcfd
chiefcfd's Avatar
Anybody got any ideas?
Old 12-11-2016, 12:24 AM   #4
Daves70
Daves70's Avatar
This is common with the Edelbrock carb. I don't think it has anything to do with the tank location. My truck did it with the stock tank too.
Daves70 is offline   Reply With Quote
Old 12-11-2016, 10:10 AM   #5
Shinysideup
Shinysideup's Avatar
I suspect the fuel pump is bleeding off the fuel. I had an inline six ford that would do the same thing .
Shinysideup is offline   Reply With Quote
Old 12-11-2016, 11:20 AM   #6
bhemingson
Put an electric fuel pump in line near the tank. Electric pumps push fuel not pull like a manual.put it on a separate switch and run it a few seconds before turning over engine and you will have fuel to your manual pump.
bhemingson is offline   Reply With Quote
Old 12-11-2016, 11:33 AM   #7
weq92f
weq92f's Avatar
You could install a check valve just behind your mechanical pump ( toward the tank ). That should keep the fuel close enough to minimize the time to prime things again.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-12-2016, 12:57 AM   #8
ufbugman
I have the same problem on my rear tank, planning on a electric fuel pump close to the tank turn it on by a switch and after truck starts shut it off.
ufbugman is offline   Reply With Quote
Old 12-12-2016, 09:44 AM   #9
67 chevelle
67 chevelle's Avatar
Its the carb running dry , truck should run for 30 to 45 seconds on just the fuel in the carb bowl , so yours is running dry
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 12-12-2016, 06:42 PM   #10
chiefcfd
chiefcfd's Avatar
That makes sense, but it takes less than a week without being started for this to happen. I'm really thinking about an EFI kit.
Old 12-12-2016, 08:54 PM   #11
haysonj
haysonj's Avatar
You have a leak somewhere that is allowing air into the line and it siphons back to the tank. My FI pump runs about 2 sec and the truck starts on the first revolution whether on the front or back tank. My truck sometimes sits for a month between car shows.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-12-2016, 11:41 PM   #12
HO455
HO455's Avatar
After sitting and before trying to start the engine look down the primaries and wing the throttle watching for fuel being pumped in by the accelerator pump. No fuel shot could indicated no fuel or a bad accelerator pump (or possibly the check ball isn't seating). Then crack the fuel fitting at the inlet to the pump and see if fuel runs out. If not then your problem is in the line or the pump diaphragm. If you have fuel at the inlet then try the outlet. If no fuel then I would look at the fuel pump. If you have fuel at the outlet then I would say your float bowl is leaking. This is a common problem with Q-Jets but I don't know about Edlebrocks. But remember that it is perfectly normal for the fuel to evaporate out of the bowl in hot weather in just a couple of days. That is one of the reasons carbs have disappeared from new cars is that that evaporation counts against emission results in the eyes of the EPA.
RIP Bob Parks.
