Old 12-12-2016, 10:54 AM   #1
fredhlynch2
Gas Gauge and Boyd Fuel Tank
Anyone know how to make a 64 C10 gas gauge work with a new Boyds aluminum gas tank and Boyds fuel sender. Is it an ohms issue?
fredhlynch2 is offline   Reply With Quote
Old 12-12-2016, 11:35 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Gas Gauge and Boyd Fuel Tank
Reading on other forum the solution is a 50 ohm resistor or an adjustable reostat. But I am going old tank to new gauge. I need to see if my float is still floating. Speedway Motors had a video on YouTube or Autometer.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-12-2016, 07:58 PM   #3
PGSigns
PGSigns's Avatar
When you order the tank all you have to do is select the 0-30 ohm sender. Mine works fine in my 66. You will be good to go.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-12-2016, 08:26 PM   #4
zach_carver
zach_carver's Avatar
My 30 ohm sending unit works perfect from Boyd's? Works great with my stock gauge.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 12-12-2016, 08:32 PM   #5
Mathew21
Mathew21's Avatar
Jimmy
Yep that's what I did.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-12-2016, 10:09 PM   #6
Kenfuzed
Kenfuzed's Avatar
+3, specify the 0-30 ohm sender and you'll be good.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-12-2016, 10:15 PM   #7
Joemomma1
Joemomma1's Avatar
I did the same but it's tough to gauge how accurate it is when it's less that a quarter full. Anyone seen this?
Joemomma1 is offline   Reply With Quote
Old 12-13-2016, 12:36 AM   #8
Kenfuzed
Kenfuzed's Avatar
I've always had that problem even with the stock tank where accuracy rapidly falls off below 1/4 tank. I'd be curious to know if it has anything to do with the sensitivity of the narrower range (0-30 as opposed to 0-90 ohm).
Enjoying the ride!
Old 12-13-2016, 12:48 AM   #9
Pro Performance
Pro Performance's Avatar
You do have a 0-90 in your tank, and a 0-30 will get it all working right.
Pro Performance is offline   Reply With Quote
