Old 12-16-2016, 07:28 AM   #1
canadian_diesel1964
Some advice on front cab supports please....
Hi guys...finally gotten around to starting the rust repair on the Alabama cab...I replaced the pass side front support it was 1/3 gone and was a pain in the butt...the drivers side has only 2 bad spots as shown....should I just patch? With the lack lustre fitment of the after market panels I think I may have answered my own question...here's a pic..thanx for any advice in advance ...63 Swb c10 micro buck build
canadian_diesel1964 is offline   Reply With Quote
Old 12-16-2016, 07:29 AM   #2
canadian_diesel1964
Re: Some advice on front cab supports please....
Pass side in.....
Old 12-16-2016, 08:05 AM   #3
PGSigns
PGSigns's Avatar
If the rest is solid I would patch it. I am all for replacing as little original steel as I can.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-16-2016, 08:13 AM   #4
canadian_diesel1964
Thanx Jimmy ! That's what I was thinkin...plus eliminates a lot of foul words
Old 12-16-2016, 02:30 PM   #5
canadian_diesel1964
Lots of foul words today....there was more rust than anticipated...had to use the other repro piece....totally misfit and actually too short with bending the ears ever so slightly ...has anyone ever run into this issue?
Old 12-16-2016, 04:15 PM   #6
Vinceg
Vinceg's Avatar
I had the same problem. I ended up spot welding in some L shaped prices to make up for the short support.
Vinceg is offline   Reply With Quote
Old 12-16-2016, 06:07 PM   #7
leonphelps
+1 for the "L" shaped pieces on all four cab mounts.
leonphelps is offline   Reply With Quote
Old 12-16-2016, 08:40 PM   #8
canadian_diesel1964
Seems like it's short on one side only since the long support it goes to is angled...L shaped brackets it is!
