Old 12-12-2016, 03:19 PM   #1
tap500
67-72 GMC Grills
I have a 71 GMC and would like to have an all chrome Grill. The 71-72 has a chrome grill that is painted black in the center sections and the 68-70 does not have these areas painted black.
I am planning on buying a new grill from LMC, Bothers, or Classic. Can I buy the 68-70 Grill and use it on my 71 without any modifications? It appears the fenders and grill outer trim are the same 68-72 on the GMC.
tap500 is offline   Reply With Quote
Old 12-12-2016, 03:25 PM   #2
Foureye71
Foureye71's Avatar
Re: 67-72 GMC Grills
I have a 69-70 grill on my 71 and as far as I know the 69-72 gmc fenders are the same and the gills should all bolt on.
'71 K1500 Short-Wide
'86 K30 C&C
'89 Iroc-Z
Foureye71 is offline   Reply With Quote
Old 12-13-2016, 09:43 AM   #3
StingRay
StingRay's Avatar
You can use the older grill. Generally you can remove the paint from a 72 grill and have an all chrome grill as well. They look just fine all chrome.
You can use the 67-68 grill too but you have to add the later top bar to them.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 12-13-2016, 10:33 AM   #4
all 67-72 GMC grilles have the exact same dimensions and are totally interchangeable. The top bar is a separate part and those are also totally interchangeable. The only difference in the grilles is in the design/styling. The top bar goes by the hood, 67/68 or 69-72.
You can strip the accent paint off a 71/72 grille, but you will still have a different grille with a different design. It might be the narrower bars and smoother look more than lack of black paint that caught Tap500's eyes.
Old 12-16-2016, 01:14 PM   #5
tap500
So if I use the 71-72 top and side trim on my 1971, I can use any 67-72 grill?
I was planning on using the 68-70 grill and stripping the paint off. The 71-72 has more paint to strip.
Old 12-16-2016, 04:03 PM   #6
That's right.
Old 12-18-2016, 12:12 AM   #7
Tim Christian
Tim Christian's Avatar
Any Key Part dealer can help you with a all chrome 71-72 style with no paint.
Tim Christian is offline   Reply With Quote
