Whats this part on my speedo cable (NP205)
Looks to be some kind of a conversion unit..truck is in MPH and I am in Canada. Could it be that this is an old school MPH/KMH convertor? Truck has 35's and at 100KMH speedo says 50 mph..at 120 KMH it reads 60 MPH on speedo...It's leaking that's why I ask. (72 K10)
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Whats this part on my speedo cable (NP205)
I forget what it's called but yes, that is to correct the speedometer reading. They can also be used to correct the speedo when changing tire size (height) or changing differential gear ratios.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Old member
Inline-Gear reduction is what I think it is from my old memory.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Oct 2009
stewart warner made them among others. primary purpose is to correct the speedo due to a change in something - tires size as pointed out, etc. But you posed something I hadn't thought of before - wonder if that was common piece for an oconus truck for kmph. There weren't any kmph speedo faces were there? I've got one of these lying around somewhere, but it leaks like crazy, ha.
You can still purchase those here if you need to:
https://transmissioncenter.net/?swoo...edometer-gears
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
If you take a look at the link I posted there is a speed adapter that is made for converting a MPH speedo to a KPH. It is a 61% ratio so that your speedo needle will be at 100 when driving at 100 KPH (62 MPH). 120 KPH would look cool in a video because the label would still be the same (MPH). Who has ever done 120 MPH in our trucks?
6>8 Plugless........
![]() Join Date: Sep 2007
I'm pretty sure all the 4x4 67-72s had these on them to correct the speedo readings. There for a while they were really hard to a hold of.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
I know this thread is getting up there in age... ...but.
My 71 C10 has one of these on it. The truck belonged to my grandparents until they eventually passed away. From there it was passed down to my uncle who put large balloon-like tires on it. When he passed away, the truck was passed down to me and I put standard size (according to Discount Tire's computer) radials on it. The Speedometer is off, I forget to what degree. When I found this device, I'd assumed my uncle had installed it because of the large tires he was running. I removed the device, and found my speedometer/odometer to be off by 20%! Didn't take long before I put it back on. I used a GPS trip tracker to compare the odometer and speedometer values. This is in the land of MPH!
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
Those adapters are sold marketed here in Sweden as MPH/KPH adapters. I see they also come in many different gear ratios for other purposes. There are many cars and trucks here imported from US that use them for the MPH/KPH purpose. Trucks that were sold new by GM here did in fact have a KPH speedo from factory, you can see one in my avatar.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
Yes,they were made and installed by GM.
I have a couple of them NOS in the original boxes. Mike. ![]() |
