2wd conversion Rear spring mount . ?help?
I'm trying to find a picture of a 4wd to 2wd conversion and what peopl used for the rear spring mount at the frame on a coil spring rear Suspension.
My conversion has a massive mount on the frame which prevents me from getting the vehicle as low is I would like. Thanks ! |
Re: 2wd conversion Rear spring mount . ?help?
I used a 3"x 3" angle 5" long, (2) 5"x 5" plates under the frame on each side. also 3" drop springs. and 1" drop blocks.
![]() Join Date: Jan 2013
I had a bad experance with drop blocks, to much body roll. Any one else?
Any other ideas?
