Old 12-20-2016, 08:53 PM   #1
AcampoDave
AcampoDave's Avatar
Re: Anyone know if this part is available ?
Try these guys www.steeringcolumnservices.com When I needed a rare part for a Caddy tilt/tele column, they had it.
AcampoDave is offline   Reply With Quote
Old 12-21-2016, 06:18 PM   #2
Captmatt
Thanks for the info, sent them a message with a photo. Fingers crossed !!
Captmatt is offline   Reply With Quote
Old 12-21-2016, 09:56 PM   #3
Kenfuzed
Kenfuzed's Avatar
Maybe that is specific to the manual shift because I don't remember seeing that in my 66 w/auto. I just bought a new turn signal assembly and it has the bearing which supports the steering shaft.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-22-2016, 06:50 PM   #4
Captmatt
Copy that, I have a upper shaft bearing . The part I'm seeking supports the inner shifter tube. With out the part there is serious play and wobble in the steering column. It's a plastic part and I'm sure they get brittle and break over time. Thanks for the reply
Old 12-22-2016, 11:28 PM   #5
luvbowties
luvbowties's Avatar
Smile Re: Anyone know if this part is available ?
Check suppliers for horn button and turn signal parts.
Sam
luvbowties is offline   Reply With Quote
Old 12-23-2016, 12:22 AM   #6
LT1 Burb
LT1 Burb's Avatar
I've taken a few columns apart and never seen that part there, something doesn't look right.
LT1 Burb is offline   Reply With Quote
Old 12-23-2016, 02:08 AM   #7
Kenfuzed
Kenfuzed's Avatar
Comparing this exploded view to your part I don't see where there would be a plastic spacer or washer. The only washers are the one above and below but neither are plastic.
The only lower gear shift washer I've seen looks like this:
http://www.ebay.com/itm/NOS-Chevy-Pa...-/271548781208
Enjoying the ride!
Old 12-22-2016, 06:45 PM   #8
Captmatt
Thanks for that info. Good web site but they told me they do not have the part I'm looking for. Darn it
