Old 12-21-2016, 05:31 AM   #1
LeesTruk
Re: Tach to Pcm
You're gonna need what's called a "Pull-UP" resistor. Just put a 1K ohm resistor from your tach power wire to the tach signal wire. Also, if using an aftermarket tach, make sure it's set for a 4 cyl. engine. The PCM tach output is designed with that sort of signal pulse
LeesTruk is offline   Reply With Quote
Old 12-21-2016, 02:03 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: Tach to Pcm
I have a in dash Factory style tach but not factory original How do I change it to 4 cyl or can I
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-21-2016, 02:20 PM   #3
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: Tach to Pcm
If the tach is reading approximately half of what it should be, then you don't need the resistor. If the tach is barely or not moving at all then you need to put a 1K resistor from a switched power source into the tach feed wire. This will boost the signal.
Now, back to reading half of what it should. The signal from the PCM is similar to what a 4 cylinder would produce. This is why you can switch aftermarket tachs to 4 cylinder mode and they read correctly. If the tach you have isn't switchable, you can have a tuner change the tach output to make the tach read correctly.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 12-21-2016, 08:22 PM   #4
1970 CST Short Wide
Senior Moment
Re: Tach to Pcm
Mike
Thank you, that helps a lot
Steve
Pittsburg Ca
94565
Old 12-23-2016, 12:50 AM   #5
68c10airstream
68c10airstream's Avatar
Re: Tach to Pcm
I have the 8,000 rpm aftermarket stock cluster kit installed and the pcm put out the wrong signal and after talking to avatar "critter" from "lone star dyno" i sent my pcm to him and he did the required mods and tested it on 2 different tachs before he sent it back. He said the signal needed to be changed in 2 ways, i believe from 4 cyl to 8 cyl and had to rescale it. He said this worked better than the pullup resistor, but i can't verify it. He was fair and took the time to double check it before sending it out. His name is Terry.
I did the ls1nova cluster changes and between eric (ls1nova) and terry it came out great.
68c10airstream is offline   Reply With Quote
Old 01-02-2017, 08:40 PM   #6
1970 CST Short Wide
Senior Moment
Re: Tach to Pcm
Steve
Tried the 1K resister and it made my tack go backwards
Pittsburg Ca
94565
Old 01-02-2017, 10:40 PM   #7
BBPanel
Re: Tach to Pcm
The purpose of the pull-up resistor is to change the +5v pcm tach signal to +12v - it worked for me on my Autometer tach. Sure you have the resistor in the correct direction - have no idea what it will do if not.
Here's a reference: http://aeromotiveinc.com/wp-content/...leShooting.pdf
BBPanel is offline   Reply With Quote
Old 01-02-2017, 10:47 PM   #8
1970 CST Short Wide
Senior Moment
Re: Tach to Pcm
Tried both power and lead to pcm. Lead did nothing power went backwards
Pittsburg Ca
94565
