11-29-2016, 06:27 PM | #1 |
What Is The Best Fitting Exhaust For Our Trucks ?
here is my info 350 Sbc with TH350 Trans Motor Sits back close to the Firewall .. and a 1 piece Drive Shaft Currently there is Long Tube Headers on it but rusted and beat up and i want to get new ones but the ones on it kinda make Spark Plug Changes a PITA lol so im looking for the best fit Long Tube ( full length ) headers for this that dont make tune ups a big deal aswell .... if it wouldent be to much of a problem would you also include Part Numbers for me ? thanks guys Happy Truckin
12-19-2016, 06:09 PM | #2 |
Re: What Is The Best Fitting Exhaust For Our Trucks ?
I would talk with the people at Hedman Headers or another header company. Some offer lifetime warranty against warping on their product. They are a great resource. Are you running straight or angle plug heads? Is your motor stock? How much do you want to invest in a nice set of Hi Temp coated headers that wont rust? If you are running a performance motor you will want to run the larger exhaust port at the head with a 3 inch collector. I am running Hedman Headers for angle plug heads, part #500-69088. Don't waste your money on cheap unknown junk headers. Plugs are not easy to change with headers. Straight plug heads are easier to change. My truck is stock height. 1966 SWB SS 355ci w/turbo350. Hope this helps.
12-20-2016, 01:02 AM | #3 |
60-66 Nut
The best fitting headers with easy plug access are the headers made specifically for these trucks. Hedman 69260's.
12-20-2016, 01:43 AM | #4 |
12-20-2016, 11:41 AM | #5 |
Never Ending Projects
Summit or Jegs is likely going to have the best price. This is the ones I am looking at for the panel.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-20-2016, 05:17 PM | #6 |
What ones mike ..... there is no link posted .... unless you were saying the same ones they said too ? Just looked like your post was ment to have a .... see here they are ? Ty brother
12-21-2016, 12:47 AM | #7 |
60-66 Nut
Sorry but no I do not. I typically buy the plain painted steel headers, have them sand blasted and paint them with 2-3 coats of wood stove paint.
12-21-2016, 11:35 AM | #8 | |
Coated, https://www.summitracing.com/parts/hed-69266 Uncoated, https://www.summitracing.com/parts/hed-69260
12-21-2016, 02:03 PM | #9 | |
12-21-2016, 03:50 PM | #10 |
No problem bro. Guess it seemed a little misleading. All good.
12-21-2016, 03:52 PM | #11 |
