Old 12-21-2016, 10:49 PM   #1
IXLR82FAST4U
1972 trailing arm crossmember
hey guys, I have a 72 c10 longbed and I bought a trailing arm crossmember from LMC, essentially it came from cpp, but I'm hearing that this wont work with a long bed truck , is this true and why?
IXLR82FAST4U is offline   Reply With Quote
Old 12-21-2016, 11:06 PM   #2
clay68c10
clay68c10's Avatar
Re: 1972 trailing arm crossmember
It should be the same for long or short.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-21-2016, 11:36 PM   #3
IXLR82FAST4U
I hope so , there was a piece of paper that came with it that said it was for a short bed but LMC didn't specify long or short bed , this is why I don't do this for a living anymore...
Old 12-22-2016, 10:55 AM   #4
Couch
Daily Driver
Couch's Avatar
the long beds have the carrier bearing there for the driveshaft. swb do not have the provisions for the bearing for the two piece driveshafts. look at pbfab.com and see their 2 different photos for options for a better understanding of what im getting at.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 12-22-2016, 12:41 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
Yes it will work with a long wheelbase. Both short wheelbase and long wheelbase trucks came from the factory with a two piece driveshaft and carrier bearing, although there are at least three different types of carrier bearings. If you plan to keep your two piece driveshaft you need the carrier bearing bracket that bolts to the crossmember (which is mentioned on their website).
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-22-2016, 01:08 PM   #6
demian5
demian5's Avatar
Originally Posted by 67c10rustbuket View Post
yes it will work with a long wheelbase. Both short wheelbase and long wheelbase trucks came from the factory with a two piece driveshaft and carrier bearing, although there are at least three different types of carrier bearings. If you plan to keep your two piece driveshaft you need the carrier bearing bracket that bolts to the crossmember (which is mentioned on their website).
x2
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-22-2016, 07:40 PM   #7
leftybass209
leftybass209's Avatar
Many short beds also have carrier bearings.
leftybass209 is offline   Reply With Quote
Old 12-23-2016, 12:18 AM   #8
IXLR82FAST4U
okay awesome thanks guys!
