Old 03-25-2004, 08:59 PM   #1
AlbertaBoy
Question VIN info
Hey lads and lasses, I'm new to the board and am glad it is here. Hope someone can help me. I have a '69 or '70 GMC 1/2 ton. Based on the VIN decoder on the site, I haven't learned much. It doesn't match up with my VIN. My truck is Canadian but I don't think that should change much. The VIN is CS134-1Z53376. I'm not sure if that first 1 is a 1 or an I but I think it's a 1. I am wondering if the stock six that is in it is the 292 or the 250. I have to get some parts and that would be good to know. It's been sitting for like 8 years and it is finally time to finish it. Let me know what you know. Thanks.
AlbertaBoy is offline   Reply With Quote
Old 03-25-2004, 09:32 PM   #2
Hutch
Hutch's Avatar
TAlbertaBoy
That looks like a model instead of a VIN
The C is for Chevrolet
The S is for six cylinder
Not sure of the rest
Get the number off of the trim tag on the door jamb tag or the title.
It should start with the same CS but will be 1 long number
The 292 will have the numbers embossed on the block and the motor mounts are staggered.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 03-25-2004, 09:43 PM   #3
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Hi and Welcome to the board.
According to the Factory Assembly Manual I have your truck should be:
C = Conventional Chassis 4 x 2
S = V 6 Gas
1 = 1/2 ton
34 = Cab and pick up box ( Fleetside? )
- = no State Certification code
1 = Made in Oshawa
Z = 1970 15 Series
53376 = is the Unit made. 53,376th one made.
You will probably have to get the ID #'s off the engine to figure out what size it actually is.
GMC VINs don't cross over with Chevys from what I have figured out. Under Chevy, mine is a '64 Chevy not a '70 GMC.
Hope this helps. Also, do you have any pics of it? You'll see this alot on here.
Mike
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 03-26-2004, 12:49 PM   #4
Rod
TsgtE662 got most of it right... but its a straight 6 not a v6... v6 code was letter M.
Also the latter part of the vin is the sequence number ... not really the number built for production. There was a starting number... and in this case it may have been 50000... so its the 3376 built at the Oshawa Canada plant. Different factory plants had different starting numbers. 34 was fleetside box type. Good job overall decoding it though. The GMC vins stump quite a few people.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-26-2004, 01:42 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Wasn't the V-6 (305/351) avalible in one tons in 70?
Old 03-26-2004, 03:38 PM   #6
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
The Factory Assembly Manual and the Chevy ID Number Catalog show the S letter as for a V6 Gas. Neither show a M letter code. I don't know how the Canadian VINs coding differ if any. I haven't seen the M code before. Wouldn't it be for straight sixes? Or would that be where the difference is between the US and Canadian VINs? I don't see why it should be different, but then I am fairly new to all this. And like to learn more on it.
i.e. Tank Rat
Old 03-26-2004, 04:01 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
The 305 and 351 V6's (CM and KM) models are GMC only, therefore a Chevy catalog would not show them. Nothing to do with Canadian vs US VINs
CS indicates an I6 for both Chevy and GMC, and unless there is an RPO isted for a 292 engine on your glove box, then it's the base 250 (assuming original engine of course).
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-26-2004, 05:54 PM   #8
67chevemall
67chevemall's Avatar
That CPNE knows his stuff!WOW!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-26-2004, 08:25 PM   #9
Longhorn Man
Mine is a CM truck, and it was built here in the US. And it did come with a 305 V-6. Chevyfatman has one too.
Old 03-26-2004, 08:36 PM   #10
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Ya learn something everyday, especially on here.
Thanks, gonna have to update my "file" now for future refs.
When I went to add your info about the M code and I 6, I found that I already had it in my notes. Which I didn't look at before, only those two books.
Oops.
i.e. Tank Rat
Old 03-26-2004, 11:15 PM   #11
Rod
I guess I shouldn't have said Canadian vins earlier... I editted it...it was more correct to say that style vin identification is more typical for 1970 and 1971 GMC's.
Thats the first I've seen of a v6 in a light duty truck past 69 in this vintage era. Vin says its made in St. Louis from what I can read.
Just goes to prove that GMC's were made in the USA and Canada and not just in Canada as some urban legends say.
TsgtE662.. your listed addy is from St.Louis... they still do GMC's there.
Old 03-27-2004, 01:06 AM   #12
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Rod - I don't think they do anymore. The only auto plants around here that I know of is the Chrysler plant in Fenton and the F**d plant a couple of miles from me. My 70 GMC was made here, my '92 came from Indiana.
I posted a thread a while back asking for VIN info for basically all GMC trucks to try and compile as accurate as possible a decoding list for everybody to be able to use. But not very many responded to it. I would still like to get one made up.
I would think that with so many people on here who know so much about these trucks we could do it and maybe end up getting included on the web site along with the Chevy decoder part. We would probably have the only site that has it.
i.e. Tank Rat
Old 03-27-2004, 01:17 AM   #13
Rod
Ive posted enough pics and scan of gmc vin decoding procedures over the years.. I'm sure myself and others have a good probable collection of materials.
Maybe Ill get around to it.
Old 03-27-2004, 04:14 PM   #14
AlbertaBoy
Wow, good to see a board with a wealth of knowledge. I still don't know what motor it is though. It would either be a 250 or a 292 Straight 6. Is there a good way to tell them apart short of cleaning all that crap off the block which I should do anyway...
Old 03-27-2004, 05:26 PM   #15
Rod
Easy way to tell is by the size of the covers that cover the lifters on the passenger side of motor... if there about 4 inches tall there a 250 size engine... if there closer to 6 inches tall there a 292.
If your glove box dosent list an option of a 292 then it probably isn't if its the orignal glove box sticker also. Original standard equipment motor would have been a 250 and it wouldn't have been listed as an option because its standard equipment.
Old 03-27-2004, 06:02 PM   #16
Rod
292, note side cover size, also the fuel pump is behind the motor mount.
Old 03-27-2004, 06:21 PM   #17
AlbertaBoy
Well thanks. It would appear that I have a 250 on my hands. Well, get it running, finish the truck, then look for more displacement. Someone swapped a 4 speed manual in and did a sloppy job. I guess I have a bit or work to do. Along with my other project, this could be a long summer. Building a FORD Bronco II into a decent trail rig. 351W, Dana 44's, and 35" Boggers. I would like to be loyal but I think everyone deserves a chance. Besides, who else is gonna have one. Thanks again.
