Old 12-20-2016, 03:52 AM   #1026
Grizz1963
Grizz1963's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Dads suburban looks great on the pics.
Glad you found a nice car and a runner.
Your honey hole is an even better find, especially if you plan on doing another truck in future.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-20-2016, 11:39 AM   #1027
AJCK87
Beauty find! Will have to go over there with you next time I'm in the Okanagan
AJCK87 is offline   Reply With Quote
Old 12-21-2016, 12:58 PM   #1028
62stepside longbox
62stepside longbox's Avatar
Thanks rian, the burb isn't too bad, but still tons of work to get it where we want it. And the truck parts find is definitely a score, I don't know about another truck though
For sure Anthony, let me know!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 12-21-2016, 09:07 PM   #1029
62stepside longbox
It's been too cold to work outside for the past month but today it got quite a bit warmer and up to 5 degrees Celsius so I prepped the front section of the frame for paint and painted it with my favourite rustoleum gloss black. There are a few spots I didn't paint because they still require Welding such as the steering box area and upper shock mounts that still need to be relocated. It turned out pretty good, definitely looks better. Now I can finally install and bolt in the crossmember for the very final time
Old 12-21-2016, 09:09 PM   #1030
62stepside longbox
Also painted and detailed the firewall paint line and painted the Bellhousing crossmember and the underside of the tunnel. The green and black sure look good together
Old 12-21-2016, 09:37 PM   #1031
TJ's Chevy
TJ's Chevy's Avatar
Nice work
Old 12-22-2016, 06:21 AM   #1032
5 degrees, even C is this down here, definitely no painting weather.
Nice work!
Old 12-22-2016, 06:50 PM   #1033
62stepside longbox
Originally Posted by TJ's Chevy View Post
Nice work
Thanks buddy
Nice work!
Thanks, it should be fine lol. This paint does fine with the cold, just takes a little longer to dry fully
Old 12-28-2016, 09:42 PM   #1034
62stepside longbox
Yesterday I went with my dad to my favourite little goldmine and picked up a bunch of parts, my dad got a really nice 67-68 slope nose hood with the trim and all the letters, a set of really nice suburban barn doors to replace his rusty ones, two partly damaged 67-68 Chevy grilles to weld together to make one good grille plus the aluminum trim and Chrome headlight bezels. He only paid $300 for all of this. Here is the grille I just finished welding together (the wood is just screwed in to help with alignment)
Old 12-28-2016, 09:44 PM   #1035
62stepside longbox
And I pulled this chrome mirror from a 61 cab for my truck as the cast part is broken on mine
Old 12-28-2016, 09:46 PM   #1036
62stepside longbox
And I also pulled this radio delete plate from a 64-66 gmc 4x4, I only gave $10 for the mirror and radio plate
Old 12-28-2016, 09:53 PM   #1037
62stepside longbox
And then today I made some spacers to go between the crossmember and the bottom of the frame (since 60-62 frames aren't as tall there's a gap) and then bolted in the crossmember for good, it's not coming out again. So the next step is to bolt on the lower control arms, install the springs and spindles so I can put the wheels back on and set the truck back on the ground, and then attach the motor mount perch onto the crossmember and then install the engine for good.
Old 12-28-2016, 10:25 PM   #1038
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nice Junkyard finds.
I see you cut out that section of frame to install your ps box.
Will you be welding that section back in, or do have some other idea?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-28-2016, 10:32 PM   #1039
62stepside longbox
Thanks, yes I will be welding it back in, I just need to get some welding gas since flux core isn't going to cut it on something as important as the frame.
Old 12-28-2016, 10:46 PM   #1040
LostMy65
LostMy65's Avatar
So, will you then use longer bolts through the full width of the frame channel?
Old 12-28-2016, 11:15 PM   #1041
Nice parts day you guys had. Good to see you can still find trucks like ours in yards.
Old 12-28-2016, 11:27 PM   #1042
Advanced Design
Advanced Design's Avatar
Hey Nik, that was some good finds in the salvage yard!
I've been enjoying your build and gotta say I was really impressed when I figured out you are doing most of your work outside. Wow! Your dedication is awesome.
Advanced Design is offline   Reply With Quote
Old 12-28-2016, 11:57 PM   #1043
namloc
namloc's Avatar
Nik. You are a hustler and your build is fun to watch come along. You got ambition for sure.Use what you learn and pass on the teaching's in the future.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 12-29-2016, 01:54 AM   #1044
62stepside longbox
Yes, just as it was on the 60-62's from the factory
Yes, they are definitely starting to get scarce, I'm glad I found this spot though.
Thanks Doug, yes working outside when it's zero degrees isn't fun but I just layer up in some warm clothes and do what I have to do, I'm not gonna let a little cold weather stop me
thanks, I try to just keep on pushing and pushing so that the truck gets done, I'll be so happy When I'm finally able to drive it.
Thanks for tuning in everybody
Old 12-29-2016, 11:57 AM   #1045
TJ's Chevy
TJ's Chevy's Avatar
Nice finds! Frame is looking good!
Old 01-08-2017, 02:43 AM   #1046
62stepside longbox
Thanks tj
Things have been slow lately because of weather like this, but this evening I went outside and braved the cold to get some work done
Old 01-08-2017, 02:46 AM   #1047
62stepside longbox
I got the control arms, spindles and brakes installed on both sides, the springs will go in at a later date when I can get access to a spring compressor.
Old 01-08-2017, 02:54 AM   #1048
62stepside longbox
Then I loosely bolted up all the steering linkage and clamped the idler arm to the frame just to get an idea of how well everything is going to line up.
Old 01-08-2017, 02:57 AM   #1049
62stepside longbox
Everything is lining up great, there is just the right amount of clearance between the centre link and crossmember, about 1/4" or so. Next step is to clean up and paint the steering linkage, then finish welding up the frame where the steering box mounts
Old 01-08-2017, 10:33 AM   #1050
Advanced Design
Wow, and I saw a post a guy was complaining his shop was 40f....gutsy progress!
