09-23-2015, 09:46 AM | #76 |
Re: OEM looking fendertriming for 37" tires
So I started playing with MS paint and this is what i came up with for the 73-80 fenders. I didnt do it to scale but i figure this is about 1" forward, 2" up and 2-3" back. Also you could go a little higher with the "fang", I moved it about 3-4" up.
Stock After reworking, the red lines are where the cuts would be and the arrows are the direction each section would be moved. Might take some trial and error though. Seems so simple in Paint!
1991 Chevy Crew Cab R3500 to V3500 Conversion Project: Build Thread Photo Bucket Pics You cant fix stupid, and stupid hurt! Rules to live by. |
09-23-2015, 03:49 PM | #77 |
I plan on removing part of the back part of the fender to match the front length. i want to run 35's but as a daily i don't want it to tall. Here's a Photochoped of what I'm planning.
09-23-2015, 04:14 PM | #78 | |
Thanks for your input!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
09-23-2015, 04:19 PM | #79 |
looks good that way, but 35´s are way easier to fit than 37s, especially if you flex it out a lot OR have an LT coilover suspension. Then the fender openings seem sooooooo small! With 35s I never had any rubbing issues at all. the 37s wouldn´t even turn at ride hight without hitting the fender!
10-26-2015, 02:35 AM | #80 |
Chevy Enthusiast
Check it out: http://ck5.com/forums/threads/new-me...talled.314470/
Not exactly what I want to do but still cool to see done. [/URL[/IMG]
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) Last edited by 1985-GMC; 10-26-2015 at 02:41 AM. |
11-04-2015, 02:45 AM | #81 | |
This is the way to keep the inner fender somewhat reusable. With what I have in mind, the inner fender either needs to be heavily modified or a custom one built. But it is really nice and helpful to see all the different approaches! Thanks!
12-29-2016, 06:18 PM | #82 |
I'm about to start the same modifications on my 1989 Suburban, Great help!
