![]() Join Date: Feb 2016
66 c10 fender to body bead and inner fender seal
Need some details on how and where to install. Any photos?
Re: 66 c10 fender to body bead and inner fender seal
here ya go
this is a huge help, thanks!.
now another question. I noticed on the fender is a secondary bracket that i am apparently missing. i have the rear fender seal bracket but not the top one. any suggestions on finding this piece out there. |
Ask in the parts section, they are out there.
thanks!
So there is some filler panels at the top as well, left. The ones on right, I believe are the radiator scoop to front panel. By the way, How are you getting staple? Fold over with pliars?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
good pixs. i need the L shaped pair on the top. The longer ones i have. they fit to the rear back section of the fender. the 4 middle brackets you have are interesting. I think i have the 2 straight ones. they fit from the grill support panel to the core support. the 2 on the left i dont have and have no clue what they are? i may need those as well. any sources?
staples? not sure yet but yes most likely using the pliers method with newer staples. havent crossed that bridge yet. |
From the Factory Assembly Manual
So that small part is called a filler for the fender.
Thanks for the cut out sheet I need that part |
I bought stainless staples from Ecklers, for corvettes, and folded them with pliers.
Good info thanks. I noticed your back side of fender was painted body color. Is that how factory was?
No, they weren't really any color, a mixture of body color, primer and undercoating. I raptor lined everything on the underside and base cleared it.
cool. how about the firewall. black or body color.?
#15 |
#16 |
![]() Join Date: Jan 2010
Classic parts sales them.
#17 |
