![]() Join Date: Aug 2016
HEI, no spark after fuel injection install
Hey folks -- finally got time to work on my fuel injection install, wrapped everything up yesterday, and I cant get it to crank. The truck ran fine before I started working on it, but regardless I'm getting the sense it's a problem with my ignition/distributor. I do NOT have any ignition control with my FI setup, it ONLY reads the tach signal off the ignition.
Now I am pretty ignorant to how these things work. I probably know less about the ignition than just about anything on the truck, but here's what's going on:
What I've done/tried:
So it seems like I don't have any issues with power or the coil. All I did to this distributor, as far as I know, is take the lid off, and plug the "tach" wire into it from the fitech. Now that its all together it won't run. It seems really hard to believe something died in my distributor during this process -- any guesses on what might be going on??? I am stumped. My next move will be to test w/ that spark tester, and if I'm 100% sure I have no spark, to get a rebuild kit for the HEI I guess... I have no no idea what kind of HEI this is, but the cover looks oldish to me...will any rebuild kit fit it or do I need to figure out what I have first? Here's a pic of my dist cover showing the "tach" terminal I've hooked up to, and the batt terminal I've tested against: http://i.imgur.com/iUq5G2I.jpg Here's my connections (red ignition -> dist batt terminal and fitech blue wire -> dist tach terminal). I have the cover off and the connections made directly for testing... http://i.imgur.com/hGt8njv.jpg Thanks all!
1969 C10 SWB Stepside, 350, TH350, FiTech Go Street Fuel Injection |
Re: HEI, no spark after fuel injection install
is the ignition module plugged into the cap?
I have forgotten the rotor in a rush to get it fired up before and the button under the coil that contacts the rotor
#5 | |
Posted via Mobile Device |
![]() Join Date: Feb 2016
Save yourself some coin and try the cheap test light method first.
https://www.google.com/url?sa=t&sour...BsTAjgAQdCF6og
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks all for your replies. elkniks nailed it... the harness from the bottom was unplugged -- with all the stuff on the back side of the intake I didn't notice it and I haven't spent enough time with these things to realize it was missing. Now that I've seen how more of it works it seems obvious
![]() Posted via Mobile Device |
