Old 01-03-2017, 01:29 PM   #1
dwreck812
How can I lift my 68 2wd c10?
I have a 68 c10 it is 2wd I wanna lift it about 6" I can't find any lift kits it has coil springs all the way around any help would be appreciated
dwreck812 is offline   Reply With Quote
Old 01-03-2017, 02:03 PM   #2
RyansToy
RyansToy's Avatar
Re: How can I lift my 68 2wd c10?
I have wanted to lift my 68 too.
I think this might be a way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=447061
1968 GMC truck
910 Trim (Canadian)
127" WB
3 on the Three Trans (Saginaw SM330)
250 ci L6 Engine
HEI ignition (early 80s L6)
RyansToy is offline   Reply With Quote
Old 01-03-2017, 02:10 PM   #3
log103
log103's Avatar
If I were you I wouldn't lift a 2wd truck it will just put more wear on parts and won't help much off-road if that's what you were going for.
'69 k10
log103 is offline   Reply With Quote
Old 01-03-2017, 02:23 PM   #4
dwreck812
I don't plan on going off road just don't wanna be like everyone else with a bagged or lowered Truck just thinking out of the box
Old 01-03-2017, 02:29 PM   #5
TwoFiftyShifter
Keep it stock height and put some 31" tires on it.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-03-2017, 02:33 PM   #6
dwreck812
Not The look I'm going for
Old 01-03-2017, 03:03 PM   #7
log103
log103's Avatar
Alright then, I just don't think there is any advantages to lifting a 2wd. I won't tell you what to do though.
'69 k10
Old 01-03-2017, 03:14 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Swap a 4wd chassis under it...seriously. With coils all the way around there really is no safe way to do it. The aftermarket does not support it with any specialty parts for our year trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-03-2017, 03:17 PM   #9
dwreck812
Afraid I was going to hear that maybe I'll look around and find a trade
Old 01-03-2017, 03:39 PM   #10
cypressbog
Go Pack Go!
Successfully lifting a 2wd is possible, but may not be the safest to do. You end up changing steering angles that affect ride quality and safety.
You can order 2-3 inch body lift kits fairly cheep. You can also put 2-3 inch coil spring spacers on it. Don't go with the coil spring clamps as that is very unsafe.
cypressbog is offline   Reply With Quote
Old 01-03-2017, 03:59 PM   #11
weq92f
weq92f's Avatar
If you do raise it up, I suspect your driving experience would suffer.
A properly lifted 4x doesn't drive at all like a stock 2x truck, so expect yours to be even further away from 'normal' feel going down the road.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-03-2017, 04:53 PM   #12
dwreck812
If it can't be done safely I'll sell the truck and find a nice 4x4 considering my litter girl and little boy ride with me all the time
Old 01-03-2017, 04:54 PM   #13
dwreck812
-klb
I've owned lifted trucks if it's done correctly it'll ride the same if not better in my experiences
Old 01-03-2017, 06:25 PM   #14
scooterpimp
scooterpimp's Avatar
Bag it & ride fully puffed up?
scooterpimp is offline   Reply With Quote
Old 01-03-2017, 06:27 PM   #15
Elliot949
Elliot949's Avatar
doing a lift like that you are going to run into MAJOR steering issues that will be dangerous... it is like what alot of guys do with their jeeps they lift them then the steering is unpredictable and they end up crashing their truck...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 01-03-2017, 06:27 PM   #16
TwoFiftyShifter
They sell spacers for coils as most "leveling" kits for late models have spacers for the front.
1982 K10 SWB
Old 01-03-2017, 07:09 PM   #17
57taskforce
All about them K’s
57taskforce's Avatar
Your on the right track... sell that 2 wheel drive truck and buy a real truck! There's far less 4 wheel drive 67-72s than two wheel. So you'll accomplish standing out in the sea of dropped/bagged trucks.
Tyler
Old 01-03-2017, 08:21 PM   #18
CK67
67 C30 3in blocks got rid of rag joint put in 2 universals, steers perfect. Go no higher than 3 in.
CK67 is offline   Reply With Quote
Old 01-04-2017, 12:00 AM   #19
brad_man_72
the boat guy
brad_man_72's Avatar
I've seen some wonky spindles used on ifs gassers. Looked like they removed the shaft out of one spindle then welded another spindle to the spindle attached to the ball joints like 8" lower.
You would be better off swapping to leafs and running an I beam in the front. The rear would need a custom panhard bar and panhard bar mount. A one piece driveshaft with a custom crossmember.
There's a couple of guys with some long travel setups that look pretty sweet.
brad_man_72 is offline   Reply With Quote
Old 01-04-2017, 12:11 AM   #20
saxart
saxart's Avatar
Not to hijack this tread, but I'd like to see pics of this!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 09-21-2018, 01:45 PM   #21
RThree
RThree's Avatar
I found a killer deal on a 1972 Longhorn but to me a truck that long needs to be lifted not dropped. So we did a 4x4 conversion on it and gave her a 6" lift at first which i determined was to high for my tastes so we dropped it down to a 4" but if you want check out my build thread it will show whats all involved. Or let me know if you have questions.
Cheers!
- 1972 K20 Longhorn, 4wd conversion. "TAWNKAA" Project. 292ci Inline 6 / '93 NV4500 / 32 spline 205 TC / Dana 60s front & back / rear Detroit Locker / 4.10 Gears / 35" BFG MT KM2 / 4" Tuff Country lift. "TAWNKAA"Build Thread http://67-72chevytrucks.com/vboard/s....php?p=6823933
- 1970 C10 Lonbed, 292ci Inline 6, 3 on the tree, stock.
RThree is offline   Reply With Quote
Old 09-21-2018, 02:15 PM   #22
rpmerf
rpmerf's Avatar
The C20 Custom Campers came with like 31.7" tires stock. Factory tire size is 235/85R16 which is skinny and tall. I got a set of 265/75R16 on 7" rims and it looks better. Same height, but an inch wider.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 09-22-2018, 07:41 PM   #23
SC1969c10
I wonder if chassis tech makes a lift spindle?
Im so sick of people talking crap about lifting a 2wd. Been reading it on forums for years. To each their own
SC1969c10 is offline   Reply With Quote
Old 09-22-2018, 08:30 PM   #24
Zone47
Zone47's Avatar
I've been wanting to lift my 68 C10 as well. I think they look cool sitting up high.
I just put some 255/70/15 tires on ralley wheels which helped slightly. I might put beefier springs in and see what that does.
Zone47 is offline   Reply With Quote
Old 09-23-2018, 05:45 PM   #25
plastercracker
there is a member here that built a off road trophy truck type machine. think it was a 67 with coils on all 4. he had a build thread to. hear is a link , maybe you will find some answers. scroll down a ways and you will see the truck. pretty cool
http://67-72chevytrucks.com/vboard/s...d.php?t=203445
plastercracker is offline   Reply With Quote
