12-30-2016, 03:11 PM | #1 |
Big block Chevy pricing
I'm looking to build a BBC to withstand somewhere in the 700-850 horse power but only push it to about 475-520 in hopes of it lasting. It would start its life as a 454. I need a recomendation of what generation to use too.
I need junkyard pricing on a a few things. (Below) 1. Block 2. Complete engine |
12-30-2016, 04:02 PM | #2 |
Re: Big block Chevy pricing
850 naturally aspirated horsepower would require some serious RPM, which in turn would require some very high dollar parts.
If you mean just the -bottom- end should be able to withstand it, then any four-bolt high-nickel block would do. I'm a big fan of the 512 castings, which were the 427/390, 427/425, and so on. They're only 2-bolt but you can drill them, and I'd rather have a splayed setup than a factory 4-bolt if I had my choice, so that's how I'd go. Good news is that 2-bolt 454 blocks are cheap like dirt. I've been selling complete running 396s with standard bore for $600, so a 454 should be in the same ballpark I'd figure. But it's the machining and parts that'll get you, of course. Unless you're going to be a full race setup, stick to oval ports (or better yet, the ZZ502 style "roval", or rectangular-oval, ports). For your horsepower level target they're ideal, and you don't lose all the port velocity like you do with a rectangular port. Then add two turbos and yer done! Will vBulletin fix sideways photos for 2017? Only time will tell, but I'm done rotating them by hand!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-30-2016, 08:05 PM | #3 |
Sideways pics are an iPhone thing, if you take the pic "landscape style" it will post properly here I have found.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
12-30-2016, 08:07 PM | #4 |
All about them K’s
I've thought about a vortec 7.4 out of a late 90s truck off and on in the past. The earlier style high flowing aftermarket heads will bolt up and you don't have to spring extra coin for a hydraulic roller cam. You also get a one piece rear main. The one down side is no mechanical fuel pump provision.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-30-2016, 08:08 PM | #5 |
i've got this one for sale. these are the heads everyone is looking for…
http://modesto.craigslist.org/pts/5926440310.html
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Thank you all so far you are angels!! Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
12-30-2016, 08:12 PM | #6 |
I have a 99,454 vortec nobody wants!
Around here a mark 4,454,4 bolt truck engine can be had for around $500.00 running.Usually they're motorhome engines. I have a couple of them in my stuff. Mike. |
12-30-2016, 09:08 PM | #7 | |
Also, if you look at the Image Properties for the image within the JPG itself, it's clear that the image I uploaded is 3024 wide and 4032 high. It doesn't get shown that way. You could make it always work by always taking pics in landscape, since that's what the forum assumes. If I'm taking a picture FOR the forum, I will. But if I'm posting a photo I took for other purposes TO the forum, the forum should deal with it. But since it doesn't, they're sideways.
12-30-2016, 09:17 PM | #8 |
Dave, I did not realize it was a forum thing. I wonder if something happened a while back when they upgraded the server?
12-30-2016, 09:22 PM | #9 | |
"They need to make sure their orientation is correct before they upload them. We don't use the EXIF data to determine orientation. Facebook goes out of their way to fix it. We do not yet do this." Which means, in layman's terms: "The user will need to manually pre-rotate their images in a paint program because we're too lazy/cheap/whatever to read the EXIF data and figure it out for them". It's up to vBulletin to fix it, so far as I can tell. Forum owners can "vote" on it being an important feature to fix here: https://www.vbulletin.com/forum/foru...-auto-rotating
12-30-2016, 10:07 PM | #10 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
12-31-2016, 10:41 AM | #11 |
Not exactly what your talking about but might be worth checking out since it is on the west coast.
http://www.chevelles.com/forums/60-w...mbo-worth.html |
12-31-2016, 11:21 AM | #12 | |
Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-01-2017, 11:22 AM | #13 |
For starters, HP cost money. Big reliable HP costs ALOT of money! In short, a well thought out 496 build will get you close to your desired upper end numbers of 700hp. There are guys over on TeamChevelle.com cranking out 496 pump gas motors with those numbers fairly often. You can expect to spend $7500-12500 if you simply order it from a builder and pick it up when its done. People might be quick to argue that you can build it for less, and in some instances you might be able to. That would completely depend on your abilities to source parts, catch good deals, and assemble the motor yourself.
For your completely realistic goal of 475-520, expect to spend somewhere in the $3500-$7500 range. Again, depending on what you have to start with and your capabilities. A well thought out stock stroke bbc can get you those numbers by using a lot production parts. If you can find a good mk4 motor with 781 or 049 heads, you'd be ahead of the curve. |
01-01-2017, 01:42 PM | #14 | |
been eye balling AFR 300cc ovals.. but I'd need to water cool my wallet.. |
01-01-2017, 01:52 PM | #15 | |
Yup.. but the 496 stroker kits/parts have come down in price.. and you have to be careful as some kits are cast steel cranks, not forged.. I'd have to look but I want to say my 489 rotating (h beam, internal balanced forged crank, 6.3"rods length, and je pistons, rings, bearings, ati balancer, and flexplate, ) was just over 3000.oo in 2003 The roller cam 1100.00 the complete 454 core 400.00 Then all the supporting parts 3 piece timing cover, hex-a-just timing set oil pan and pick up pump head studs main studs, the list goes on.. I'm sure it'll be 11-12 k when it's all said and done.. Then the rest of the drivetrain to handle it.. |
01-01-2017, 02:29 PM | #16 |
I like my big blocks to look original in these old rides, but GM is making hard to stay with that thinking, with the Connect and Cruise offerings.
http://www.chevrolet.com/performance...ruise-ls3.html For that same $11,000 you can have a dependable LS with overdrive. Don't get me wrong, $11,000 is a lot of money, but as my engine builder answers when asked "how much is it going to cost" his answer "how fast do you want to go?'
01-01-2017, 02:42 PM | #17 | |
The LS is on it's way out.. So how long G.m. will keep the L.S in the crate motor pipe line, before going into the direct injection LT.. is any ones guess.. I know one thing.. even with the craze over the LS and everyone dumping one in their rides.. big block parts have not gotten any cheaper |
01-02-2017, 10:54 PM | #18 | |
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
01-03-2017, 10:35 AM | #19 |
How do I take landscape style on my iPhone? Just turn it sideways?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-03-2017, 11:38 AM | #20 |
01-03-2017, 01:51 PM | #21 |
01-03-2017, 02:10 PM | #22 | ||
"I ain't nobody, dork."
Why would you want to ever put that much cash into an engine to run 850ish HP and then "not push it" past 520ish. Unless I read the question/comment wrong.
Total waste of time and money when you can build a 454 to make 500 HP without even trying. Most people have never even felt what 500 HP really feels like. It plants your butt in the seat toot-sweet... so no need to "overbuild" a BBC to achieve 500 HP. Gary
01-03-2017, 02:28 PM | #23 | |
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
