#26 |
Re: Blazer Seat Bracket Question
Forgot you posted the pic's and yours are the same as mine... HATE THEM! Don't know how they ended up in mine. Figured I would swap them out later.
#27 |
![]() Join Date: Oct 2008
Bought covers from LMC to small they sent me to a lady at Truck World named Dixie in Springfield,MO (417)883-8390
SHE WAS ABLE TO FIX ME UP WITH SOME SCROLL COVERS FOR FAT BOY SEATS(UTILITY) THAT IS WHAT SHE CALLED THEM. I SENT PICS IN THE OTHER TREAD TODAY. The back on these are metal and criscrossed as you said. |
#28 |
Does anyone have the rt frt seat brkt picutres or parts for a 1970 K5 Blazer?
#29 |
Sorry, no pics. But you might want to specify which seat brackets your looking for. Utility buckets or Sport buckets. The brackets are different bt. the two.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
#30 |
I guess the utility because the rt frt seat folds forward and latches when in the down position. The seat are pretty fat and the back part is low.
#31 |
These are utility buckets or fatboy seats the others are narrow with plastic backs these are metal backs.
#32 |
That is what I have. They have already been redone but the rt frt seat brackets have been missplaced. Can you get me a picture of the seat with it leaning forward?
#33 |
I will try to remember this evening when i get home. It has a center female bracket bolted to the floor and the seat has a male bracket that it sets down in which can be unlatched by pulling on a rod or using the handle you can see at the back.
#34 |
That sounds correct. I have the male part but nothing else. Thanks
#35 |
I may have an extra female bracket. maybe i will have to check.
#36 |
Here is a picture of a bracket where the latch is to the right mine is in the middle both were used. I copied this from another thread mine is the same only in the middle instead of the right.You can spot the female bracket at the bottom right.
#37 |
Thanks, I have the long bar and the hook shown on the seat but i will have to see about the rest of the brackets. This helps a lot.
#38 |
Here is mine that has brackets in the center.
#39 |
After looking at these pictures mine is different. My seats are on a 1970. Is yours a 71? Maybe they are different?
#40 |
Yes mine is a 71 blazer i think the first picture with it on the right side was earlier model just a guess.
#41 |
#42 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#43 |
Thanks so is that front to back or side to side?
#44 |
![]() Join Date: May 2006
Front to back
#45 |
I need a female bracket for the pass side seat for a 71 blazer. Also need 1 front bracket that bolts to the floor if anyone has them please let me know. Thanx
