Closed Thread
Old 01-04-2017, 02:09 PM   #4801
HO455
HO455's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Oregon 1967 GMC View Post
It's too damn cold to be doing much around here but I managed to paint my tie rod ends. I'm about ready to put the front suspension back on and hook up brake lines on drum/disc conversion.
I spent Saturday outside trying to figure out why my S10 is running poorly. Nothing like standing in the rain when it is 35* out. Having grown up in northern Idaho I know what negative numbers on the dial are like and I'd rather do that than 30*'s and rain.
RIP Bob Parks.
HO455 is offline
Old 01-04-2017, 07:32 PM   #4802
TwoFiftyShifter
I put the '88 Chevy split bench in. Don't mind the tools on the floorboard. Next is a rubber mat!
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline
Old 01-04-2017, 09:16 PM   #4803
Boog
laying low
Boog's Avatar
TFS. I've got that same 60/40 seat in blue.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 01-04-2017, 09:52 PM   #4804
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
We're in the mix of a MAJOR storm and I had to use my driver. Judging by the refills, the wiper system probably hasn't been used in decades. I bought some replacements - yeah right, they're nothing but rubber with a clip and don't work. At any rate, I broke out some spare OEMs, and they fit like they're supposed to. So I ordered another two pair.
The wiper system was a bit slow, but with use it recalled its former glory. I had removed the wiper arms months ago, but since then the truck promoted from thoughts of parting it out.
In hindsight I'd have lubed the joints some. That and WD-40 the spindles where the arms attach. I dried them by hand, but WD was the ticket, plus they'd have been easier to attach.
Moral of the story is you can buy OEM refills, don't give up on these jewels, and even when chances of success are high, take the time to do it right the first time.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 01-05-2017, 04:29 AM   #4805
Metaldoc
Metaldoc's Avatar
Originally Posted by matthamby View Post
So, how did the truck react after it's portion of the 2-kill-ya?
It has never been able to "C" very well, but the tequila helped my vision.
Metaldoc is offline
Old 01-06-2017, 03:51 PM   #4806
74baggedbug
Had the oem hinges rebuilt, they should be back Monday then off to powdercoating
74baggedbug is offline
Old 01-06-2017, 04:23 PM   #4807
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Who did they for you? I had mine by this guy Willie at http://www.hoodhingerepair.com
I haven't reinstalled them on the truck but am planning to in the Spring.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 01-06-2017, 05:30 PM   #4808
tommys72
tommys72's Avatar
Looked at it nestled in the garage....snow and ice on the ground still and its way to cold to do anything to it anyway
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline
Old 01-06-2017, 07:45 PM   #4809
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Low 40's then it dropped down into the 30's but I got the booster installed and the push rod adjusted and I now have power brakes on the Ramp Rat!
Took it out and filled it with gas and drove around to check the heat and deforst it worked good.
Brakes did too!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 01-06-2017, 08:06 PM   #4810
mud.man.rj
mud.man.rj's Avatar
That booster is just to shiney compared to the rest...
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 01-06-2017, 08:31 PM   #4811
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Andy4639 is offline
Old 01-06-2017, 09:10 PM   #4812
74baggedbug
Thats who did mine!! Hope to be installed in the next week or so
Old 01-06-2017, 09:18 PM   #4813
71CHEVYSHORTBED402
Safe to say they did a good job? Didn't realize these could be restored, but I'm beginning to realize there's a specialty for everything. Mine hinges look great, but after 40 plus years, seems a tune-up is in order. I did buy a RH NOS, but the rivets are a bit different than original, and I've pretty much given up on the LH side...............
Tony
Old 01-06-2017, 09:37 PM   #4814
Andy4639
Old member
Andy4639's Avatar
Willie rebuilt mine a few years ago and they work great. He will do them right.
You can always buy those $500.00-$600.00 Billet ones though!
Andy4639 is offline
Old 01-06-2017, 09:44 PM   #4815
71CHEVYSHORTBED402
Thanks Andy. I think I'll skip the Billets.
Tony
Old 01-06-2017, 11:18 PM   #4816
Andy4639
Old member
Andy4639's Avatar
I understand!
Andy4639 is offline
Old 01-07-2017, 08:00 PM   #4817
Andy4639
Old member
Andy4639's Avatar
Took the dash out of the Ramp Rat and cleaned it up replaced the oil gauge. It hasn't worked since I bought it.
Andy4639 is offline
Old 01-08-2017, 10:57 AM   #4818
Dave K.
Dave K.'s Avatar
After a lot of deliberation on rim and tire size choices I picked up this set of CUCV Blazer 15 x 8 rims. Going to run 31s with these and install hubcaps. Though not correct for my 68 50th it will give the "stance" I want. Thanks for all of the input from folks here in helping direct me on this.
Dave K. is offline
Old 01-08-2017, 12:48 PM   #4819
toolboxchev
I drove it around in the snow and ice, 47 years young, 12 since I have owned it. I wonder how many Toyotas are doing that? Ha, not!
toolboxchev is offline
Old 01-08-2017, 03:37 PM   #4820
Andy4639
Old member
Andy4639's Avatar
30* outside but I got the dash back in the Ramp Rat!
Oil gauge worked speedo not so much. I guess I'll go back out and start taking the heater core out. I called O Reillys and they will have it Tuesday.
Andy4639 is offline
Old 01-08-2017, 05:12 PM   #4821
ohboy321
ohboy321's Avatar
I hooked up the battery tender. The reality of winter in NH has set in, the roads are covered with sand and salt, and it it won't be going anywhere until April at the earliest.
I have new front springs in the garage, and will be installing those sometime in March.
ohboy321 is offline
Old 01-08-2017, 05:54 PM   #4822
Andy4639
Old member
Andy4639's Avatar
Heater core is out and waiting on new one to arrive on Tuesday.
Last picture is all the crap that came out of it.
Andy4639 is offline
Old 01-08-2017, 06:35 PM   #4823
firedemon
amazing how much crap mice can pack in there
firedemon is offline
Old 01-08-2017, 08:16 PM   #4824
74baggedbug
Installed the floor back in the truck
Old 01-08-2017, 09:44 PM   #4825
Boog
laying low
Boog's Avatar
That's a pretty floor alright. I am curious though about the closed in area in the left front area of the bed.
Boog
primer is finer
Boog is offline
Closed Thread
