Old 01-05-2017, 09:25 PM   #1
thefalconer_88
Brake line size?
I'm building a 63 c20 with early classic 3/4 to 1/2 ton conversion spindles and a 71 trailing arm rear end. I'm usin 1971 factory discs up front and the cadillac calipers on the rear. I was planning on using 1971 c10 brake hoses front and rear with 3/16" brake line, but the rear hose has 1/4" fittings? The calipers have hoses that came with and they end with 3/16" as well. I went from 4 wheel drums to this, so I don't have much to go off of... should I use adapters to go to 3/16" line or should it be 1/4" all the way from the master cylinder? I should note that I am using a manual corvette 4 wheel disc master and proportioning valve. The rear port is a bigger size fitting, but I have an adapter for 3/16"... Any ideas?
thefalconer_88 is offline   Reply With Quote
Old 01-06-2017, 08:51 AM   #2
PGSigns
PGSigns's Avatar
Re: Brake line size?
Run 1/4" all the way back to the hose from the frame to the rear and it should be 3/16 at the outlet on your hose.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
