Old 01-04-2017, 10:29 PM   #1
Mfsbuell
Clutch advise
Hi all, Mike here in Tracy California.
I have a 1971 c10 lbw base model 3 on the tre 250 6.engine.
Does anyone have part numbers for the "long and short" through out bearings.
I though I had a clutch issue as rod adjustment is way to the end of the rods end, thread wise .
Looking at the pressure plate edge on it has same thickness as the New kit I got from oriely auto.
And there was a thread about out of adjustment being the fault of the different t o bearing.
Ideas?
Cheers
Mike
Mfsbuell is offline   Reply With Quote
Old 01-04-2017, 11:10 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Clutch advise
Ideas?
Cheers
Mike
Welcome to the board Mike. The pressure plate and flywheel usually don't wear that much. The clutch disk is what wears and it doesn't take a lot of wear to make a big difference it clutch travel. If the throwout bearing isn't turning it will wear the face of the T.O. bearing and the pressure plate fingers. There is quite a bit of difference in the throwout bearing length between long and short. Do you know which pressure plate you have now, Diaphram or Borg & Beck style? You have to use the short T.O. bearing with the diaphram pressure plate and the long T.O. bearing with the Borg & Beck pressure plate.....
LockDoc
Leon
Old 01-06-2017, 08:34 AM   #3
Mfsbuell
Re: Clutch advise
The kit comes with the diaphragm type as far as I can make out.
To get more free travel in the pedal nuts in or out? I have less than one inch to end of rod.
Cheers
Mike
Old 01-06-2017, 10:29 AM   #4
LockDoc
LockDoc's Avatar
Re: Clutch advise
Cheers
Mike
You would have to shorten the rod length to get more free travel so the nuts and centering spacer/pivot would have to screw on the rod more. It doesn't take much to make a lot of difference so only go one or two turns at a time
LockDoc
Leon
Old 01-06-2017, 11:34 AM   #5
Wrenchbender Ret
Re: Clutch advise
If you bought the clutch kit it will have a matching TO brg. Your linkage may be worn at the pivots causing excess play & adjustment.
Wrenchbender Ret is offline   Reply With Quote
