Old 01-06-2017, 08:50 PM   #976
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Ready for fitting and trimming the two sections. Hopefully I will get a little time to work on it tomorrow...Jim
oldman3 is offline   Reply With Quote
Old 01-06-2017, 09:45 PM   #977
youngrodder
youngrodder's Avatar
Looks great Jim. It will be fixed back up in no time.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-06-2017, 10:36 PM   #978
Advanced Design
Advanced Design's Avatar
Will sure save a ton of time sectioning it in too. No doubt it will be good as you had made it (better than new) soon.
How is the quality of the new inner?
Advanced Design is offline   Reply With Quote
Old 01-07-2017, 12:20 AM   #979
oldman3
oldman3's Avatar
Marc
Thanks Marc...Jim
Doug, quality of inner is pretty good, a little thinner, but still a good piece...Jim
Old 01-24-2017, 09:29 PM   #980
oldman3
oldman3's Avatar
Hey troops, not much of an update, but it's something. Had this work done for about 2 weeks, but just now took pics.
Pic 1 I bolted the old part of inner back in place, and the new inner in it's location.
Pic 2 Checked that the radiator support holes, lined up and the front apron.
Pic 3 Push panels together scripe a line, take back out, cut and tack together for another fit.
That's it on my stuff, put I will post some other work I've been doing...Jim
Old 01-24-2017, 09:48 PM   #981
Kim57
Kim57's Avatar
Glad it's going back together.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-24-2017, 09:50 PM   #982
oldman3
oldman3's Avatar
If you don't remember, back on post #962 I said I would be working on a friends 71 Olds. Will I've been working on it off and on for 2 weeks. Removed his old B&M shifter (not working good at all), and replaced it with a Lokar unit. I didn't show anything on that, it's been done enough. But Ed decided he wanted the light up indicator also (more for his wife, not him). Anyhow this thing takes a little time to get everything in place, run cable to trans, adjust the spring on the sensor arm, etc. Then to program the controller etc. Here's a few pic on that part...Jim
Pic 1 Location chosen inside his console, for cable, sensor and controller.
Pic 2 Two different wire groups to hook into the controller.
Pic 3 All wires tied into the controller. The green light (looks yellow) shows it's in Park, each time you move the shifter to another position, the red will change to green for that gear and light up the indicator on console.
Pic 4 Indicator showing in Park, will change as started above.
Old 01-24-2017, 09:53 PM   #983
oldman3
oldman3's Avatar
Still have a few little things to finish up, install boot,storage box in console, etc. We should start on installing FiTech system next week. Will take pics, etc and post when we start. I will insert a link, so you can follow along if you want. Ed's will have the command center, which is different that mine...Jim
Old 01-24-2017, 10:10 PM   #984
55 Chevy Dave
55 Chevy Dave's Avatar
Sorry about your truck, Jim! But I'm glad to hear you are both OK. I'm sure it will be better than before the accident. What a great time to improve on perfection!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 01-24-2017, 11:17 PM   #985
oldman3
oldman3's Avatar
Kim
Thanks Kim, hope to move along a little faster, when I finish up my promise to Ed....Jim
Old 01-24-2017, 11:21 PM   #986
oldman3
oldman3's Avatar
Thanks Dave, hope I can live up to all the stuff people think I can do, I'll just do my best...Jim
Old 01-25-2017, 12:28 AM   #987
Flysocal
This truck is so cool. The matching painted frame and convertible top are outstanding. Truck was perfection but the silver lining is that to get to freshen things up. Standing by for updates...
Flysocal is offline   Reply With Quote
Old 01-25-2017, 09:42 AM   #988
Indian113
Indian113's Avatar
Glad to see your staying Busy Jim. Any other projects in the wings?
Indian113 is offline   Reply With Quote
Old 01-25-2017, 10:22 AM   #989
oldman3
oldman3's Avatar
Thank you, appreciate you checking it out...Jim
Old 01-25-2017, 10:24 AM   #990
oldman3
oldman3's Avatar
Hey Ray, just Ed's and mine for me. Mark is staying very busy, shop is full and he has people waiting. Hope to get my stuff done so I can help him a little...Jim
Old 01-25-2017, 08:08 PM   #991
Advanced Design
Jim, it is great to see the updates. I really enjoy helping a friend with their hot rod projects too...having fun and spending their money.
Old 01-25-2017, 08:17 PM   #992
lynx5653
lynx5653's Avatar
hope you are not using the fuel command center on the fitech install I had one installed and it kept boiling the fuel, changed it and went with their frame rail pump it works great.
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 01-25-2017, 11:40 PM   #993
oldman3
oldman3's Avatar
Doug, your right spending their money, makes it easy. I try to help out my friends as much as I can...Jim
Old 01-25-2017, 11:41 PM   #994
oldman3
oldman3's Avatar
Your right, heard both good and bad about the comman center, but he wants it, so I will try it. I have the frame mount pump on mine and it works great...Jim
Old 01-28-2017, 05:40 AM   #995
RockinKees
RockinKees's Avatar
You're a busy man Jim
Good to see some updates on your Roadster!!
It's always fun and good times helping friends with their projects!
I too have some side projects on hand, but that is more on the pinstripe side!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-28-2017, 11:04 AM   #996
oldman3
oldman3's Avatar
Thanks Kees, I do enjoy helping friends, some don't have the knowledge or skills for what they want done, so I help them out and they learn that sometimes you just have to give it a try...Jim
Old 01-29-2017, 01:23 AM   #997
joedoh
joedoh's Avatar
looking good!
Old 01-29-2017, 09:15 PM   #998
oldman3
oldman3's Avatar
Originally Posted by joedoh View Post
looking good!
Thank you...Jim
Old 01-31-2017, 09:53 PM   #999
oldman3
oldman3's Avatar
Sorry I'm so late posting up the final pics of Ed's shifter install.
Pic 1 and 2 are of the finished console, shifter, indicator, etc.
Pic 3 is his dash, I had removed a bad digital dash and installed these Speedhut gauges...Jim
Old 01-31-2017, 09:57 PM   #1000
oldman3
oldman3's Avatar
I need some input from everyone. Started installing Ed's FiTech unit with a Command Center. My question is should I post this in the engine section, or someplace else. I don't think the LS swap is correct even if it is fuel injection. Let me know what you think...Jim
