Old 01-06-2017, 06:00 PM   #1
machinest
machinest's Avatar
help with brakes upgrade
HI all
I have a 1968 c10 stepside . I would like to use disc brakes in the front but I have a 6 lug drum so I would like to use a 6 lug rotor . I will be using a 70's drop spindle unless that spindal is wrong anyone has an idea of what year rotor I can use? Any info will be appreciated
machinest is offline   Reply With Quote
Old 01-06-2017, 07:14 PM   #2
demian5
demian5's Avatar
Thumbs up Re: help with brakes upgrade
This is going to be a solid answer, can't wait to see what it is!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-06-2017, 07:36 PM   #3
firedemon
I am planning the same swap from everything I am reading the 5 lug was standard after 70 if you want to keep the 6 you have to use conversion rotors for the year of your spindle
firedemon is offline   Reply With Quote
Old 01-06-2017, 10:06 PM   #4
machinest
machinest's Avatar
Thanks for the info is there a year spindle that I can use and get a 6 lug rotor instead of conversion one
Old 01-06-2017, 10:18 PM   #5
poway
Hopefully this will help.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
poway is offline   Reply With Quote
Old 01-06-2017, 10:28 PM   #6
machinest
machinest's Avatar
Originally Posted by poway View Post
Thanks for the link but that only seems to be for the 5 lug. I want to able to buy a six lug rotor of the shelf from another year vehicle or it isn't possible so I have to buy a aftermarket 6 lug rotor?
Old 01-06-2017, 10:32 PM   #7
poway
You can get 6 lug rotors at The Truck Shop in Orange, CA. Someone in your area has to sell 6 lug rotors.
Old 01-06-2017, 10:34 PM   #8
machinest
machinest's Avatar
OK cool what year can I use?
Old 01-06-2017, 10:35 PM   #9
firedemon
from everything I have read most spindles are set up for either 71-72 or 73-87 and stock they were all 5 lug so your kind of stuck . I think that's why all the kits charge a bit more for the 6 lug
Old 01-06-2017, 10:58 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
HI all
Make your life EASY:
BUY,....
1) 63-70 Conversion spindles.
2) aftermarket 6-lug rotors (there is no bolt on oem rotor)
3) 71-87 HD calipers and bearings
4) 71-72 M/C
5) 71-87 proportioning valve or aftermarket
Seems like the Disc Brake thread I wrote confuses everyone.
BUT there is absolutely no need to use 71-72 or 73-87 spindles anymore.
That only makes you purchase more parts.
Donor front ends are wore out and need to be rebuilt.
You are basically converting to 5-lug EXCEPT you are using 6-lug aftermarket rotors.
(These are 5-lug blank rotors that have been drilled to 6-lug)
Keith
Convert to disc brakes.
Old 01-06-2017, 11:13 PM   #11
machinest
machinest's Avatar
Thanks for the clarification
Old 01-07-2017, 10:36 AM   #12
Mike C
Mike C's Avatar
Long term you will not regret the 5 lug conversion. Kit is cheaper now, almost pays for half the cost of axles at least from ECE which I recommend.
I did the ECE conversion on my 69 that uses the drum brake tie rods and balljoints so in the future you just buy those parts for your car. It also uses cheaper easier sourced 5 lug rotors. And your wheel choices go up exponentially both in size and style.
But like everything else, YMMV.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
