01-04-2017, 10:52 PM | #1 |
Formerly- 1972SuperCheyenne
Flat Out C4 Install Instructions
Looking for a set of the Flat Out C4 install instructions for the rear suspension. I can't find mine anywhere. Thanks for the help guys.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-05-2017, 12:23 AM | #2 |
Re: Flat Out C4 Install Instructions
If you scare up a set i would like a copy also, mines a TF so would be different probably. Do you have plans and specs for the front you built? I could sure use a copy of the front also. Have the equip and know how but hate to waist a bunch of time andmaterials trying to figure it out. Any help would be appreciated, thanks
01-05-2017, 09:01 AM | #3 |
Just contact Don at flatout..he's very helpful and I'm sure he'd shoot you a copy
01-06-2017, 07:22 PM | #4 |
He would not furnish them to me before I purchased my kit. I wanted to see how good the directions were and get an over view. IM me for more info.
01-07-2017, 12:33 PM | #5 |
I know i have my front IFS instructions as i was looking for them the other day, but
Dang'd if i could not find the rear Instructions. I will tell you the rear was pretty much detailed with drawings, But the front could of been better as they were a little vague, do a search as there is someone with an article on installing their kit and shows some better detail when you go to install, also i used the Aldan Coil overs and he shows a detail on putting a relief in the frame at the top, as the coils just touch the frame at their mounting point. If i can find it i will pass it along to you, All in all i am very happy tho with the Flat Out Kit and when i called them they were very helpful to me! Good luck with your build, Allen |
