Old 01-06-2017, 01:28 AM   #1
Lookin4the1
o2 sensor woes
while placing an order on summit i bought the wrong o2 sensor that don't match my psi harness. both 4 wire square for the gen 3 ls, but both have male ends. this led me to a few questions before i return them.
Is there an adapter made with 2 female ends that i could simply buy and hook my existing o2 sensors up.
whats the female plug part #? could i just cut and wire one end to work correctly?
also, if i'm ordering a new set, what are the preferences out there on swaps? I was just going to go with a stock type sensor being that it is only a mild built 6.0. at the end of the day the purpose is to be streetable on a daily basis.
Lookin4the1 is offline   Reply With Quote
Old 01-06-2017, 04:29 PM   #2
darrellyates
Re: o2 sensor woes
Regarding o2 Sensor...
My GM crate engine information pack calls out for GM# 12581966 or AC Delco # 213-1694. These are what GM calls for. I don't know about any adaptors, I have a harness from RCI in Huntsville that plugs right into the sensor.
I think these are kind of the universal part number for LS swaps, I've seen the AC Delco number used in multiple compatibility charts and cross references. Please note, my engine is an LS3, (6.2), but I think these are even the sensors I ran in my 5.3 swap several years ago.
Good Luck sorting out, hope the numbers help.
darrellyates is offline   Reply With Quote
Old 01-06-2017, 10:13 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: o2 sensor woes
Look at Bosch 13444 and 13474
One is male end, one is female end.
The 13444 is the "jack of all trades" sensor that most harnesses call for.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-07-2017, 12:02 AM   #4
mongocanfly
mongocanfly's Avatar
Re: o2 sensor woes
My psi harness instructions calls for gm#25161131 /delco#afs123...got mine at oriellys..or dealer...I can't remember
Old 01-08-2017, 12:42 PM   #5
elf w/capital T
Re: o2 sensor woes
http://www.autopartswarehouse.com/sk...Sensor_Harness
I did the same thing, i think this is what i spliced...
REPC381203
elf w/capital T is offline   Reply With Quote
