Old 03-26-2001, 02:07 AM   #2
Duallie
Duallie's Avatar
Post
Well, I can't directly answer either of your questions but I can list my notes regarding what I measured and calculated for the springs on my 72 1 ton and compare to what you have now.
6 coils of 7/8th wire at 4.75 pitch and 5.5 OD equals 1591 lbs max safe load EACH, with each coil deflecting .188"/coil at max load.
I've been looking for bigger springs and the biggest so far are the originals. My wife's 77 crewcab duallie w/ 10,000 lb package has the same springs as my 7500 lb gvwr 72 duallie. Every 3/4 ton 2wd that has been through my yard (8) has spring wire diameter within .020" of these, and that could be corrosion talkin'. Don't have any coils loose to measure free height for you.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
