Old 01-12-2017, 12:34 AM   #1
Bargy1
Cost of Anodizing
Has anyone had the side trim from a Fleetside straightened and anodized? I haven't found anyone in my area that performs the work and I am trying determine what it might cost versus buying a new set from Mar-K.
Bargy1 is offline   Reply With Quote
Old 01-12-2017, 08:50 AM   #2
jhrusk
Re: Cost of Anodizing
I can't speak on anodizing but if you get MAR-K trim you will not be disappointed. I bought theirs and installed on my truck and it was perfect.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 01-12-2017, 11:23 AM   #3
GMCNUT
GMCNUT's Avatar
Anodizing is about like chroming - expensive. I saw in one of the parts catalogs where you can buy reproduction full sets of 16 pieces for only 300 bucks or something. The only complaint I have heard was from people trying to use push-in clips with the thinner repop trim, and getting dings in it from pushing against the clip - sometimes this is from a novice trying to install trim who doesn't know what he's doing, and sometimes its simply the thinner nature of the repop trim, which is why I recommend using studded clips rather than push in types. If you go to www.truckandcarshop.com and buy the trim for pennies on the dollar and also buy the studded clips to do the job, there is no reason you should expect to be unhappy with the result. Two pieces of your 16 piece set are going to cost you 300 to anodize vs a whole set PROPERLY installed for that....my two cents anyway
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-12-2017, 11:39 AM   #4
Classic v6 GMC's
Classic v6 GMC's's Avatar
x2
I have heard good things about MAR-K trim.
I helped install a set from Classic Parts or LMC and it was very thin. We were being very careful and still ended up with some dings.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 01-12-2017, 12:53 PM   #5
Crazy Rusty
Crazy Rusty's Avatar
For cost effectiveness, you may want to look up how to anodize. I don't know the details but my brother just spent about $150 on the chemicals and something for the electric charge and is anodizing and selling paintball gun parts.
Crazy Rusty is offline   Reply With Quote
