Old 01-11-2017, 10:27 PM   #1
First c10
First c10's Avatar
Firewall steering column mount
Can someone tell me the uses of the attached firewall steering column mounts?
Why they are different?
Different year? Auto? Manuel? Tilt? Non tilt? Etc.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-12-2017, 01:58 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Firewall steering column mount
I honestly can't tell you for sure but I would say different years. I guess it could even be different assembly plants. If I can remember I will look at some of my trucks in the morning and see if I can tell.
LockDoc
Leon
Old 01-12-2017, 02:55 AM   #3
El Dorado Jim
good question? i will look at mine also
El Dorado Jim is offline   Reply With Quote
Old 01-12-2017, 09:37 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
The two on the right look the same to me. The one on the left may be for a medium duty truck, judging from the size of the mounting holes?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-12-2017, 09:49 PM   #5
LockDoc
LockDoc's Avatar
All 3 of my '67's, and My '68, are like the one on the left. My two '70's, my '71, and my '72 are all like the ones on the right.
LockDoc
Leon
Old 01-13-2017, 12:19 AM   #6
First c10
First c10's Avatar
Lockdoc, Can you tell me if they are manual or auto or tilt or is it just Year specific?
GO GO!!!
Old 01-13-2017, 01:18 AM   #7
LockDoc
LockDoc's Avatar
The Green '67 was an I6 with a 4 speed manual, The '67 Panel Truck was an I6 with a 3 speed manual, Not sure what the '67 C30 had for an original engine. It had a 350 and 4 speed manual in it when I bought it but the owner kept the engine/trans. The '68 has the original 327/TH400 in it. If I remember correctly the Yellow '70 originally had a 307 and 4 speed manual in it, the '71 had a 402 and Th400, and the '72 dually had a 350 and 4 speed manual..... No tilts on any of them originally.
LockDoc
Leon
Old 01-13-2017, 12:19 PM   #8
First c10
First c10's Avatar
Which would you use? I do believe the left one will have more adjustment.
GO GO!!!
Old 01-13-2017, 01:06 PM   #9
LockDoc
LockDoc's Avatar
Look close at your mast jacket/column housing, if it has one bump on it use one of the ones on the right, if it has two bumps on it use the one on the left. The bumps fit into the one raised area or the two cutouts on the brackets....
LockDoc
Leon
Old 01-13-2017, 02:12 PM   #10
kehstr
kehstr's Avatar
interested in learning about this
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 01-14-2017, 02:00 AM   #11
First c10
First c10's Avatar
I will be having them powder coated. I will use the one that fits the best. Thanks for the help guys!
GO GO!!!
Old 01-16-2017, 11:52 PM   #12
kehstr
kehstr's Avatar
So this past weekend I switched my non-tilt automatic column (1972) out for a tilt automatic column (1971 or 72, not sure). My non-tilt column used the bracket on the far right, and my tilt column used the one on the far left.
@Chad's Fab
