Old 01-12-2017, 08:39 PM   #1
Fakeshemp73
Fakeshemp73's Avatar
Right Stuff pre-bent th350 transmission vacuum line help
Hello all
I'm trying to figure out the correct routing for this Pre-bent transmission vacuum line and every way I try doesn't seem correct. I've triple checked to verify its the correct one for my application and I know I need to add a small rubber piece at the engine but the bending just doesn't line up from the modulator to the engine that I can find.
Shouldn't the line hook up at the modulator and run nice and tight up to the engine where I would then hook up a small piece of hose between the hard line and intake?
If anyone has used these pre-bend lines and has a picture how it goes I would appreciate it.
1970 C10
4.5/6 drop from ECE
Body off restomod that seems to be never ending.
Mama Tried...
Fakeshemp73 is offline   Reply With Quote
Old 01-12-2017, 10:38 PM   #2
Joesjunk
Joesjunk's Avatar
Re: Right Stuff pre-bent th350 transmission vacuum line help
I put a new one of those on a friends truck I built last year, it didn't come close to fitting at all. I ended up having to bend it up to make it fit.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-12-2017, 10:42 PM   #3
leddzepp
Moderator
leddzepp's Avatar
I have never had any pre bent line of any sort come even close to fitting. Fuel lines, brake lines, transmission cooler lines, doesn't matter, they all need to be tweaked or bent again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-12-2017, 10:56 PM   #4
Fakeshemp73
Thanks guys, I had good luck with my pre-bent brake lines and didn't have to do hardly any reworking to them. Any tricks on bending stainless steel by hand without messing it up? from the looks of it I will need to do some serous reconfiguration of that line.
1970 C10
4.5/6 drop from ECE
Mama Tried...
Old 01-13-2017, 06:05 AM   #5
Boog
laying low
Boog's Avatar
There is no nice way of putting it. If that is the right part number for your trans then they totally blew it. I wouldn't stand for it. You paid good money for it and deserve it to fit as designed, not to have to reengineer it too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-13-2017, 08:36 AM   #6
yuccales
yuccales's Avatar
Agree with Boog. That's a bummer with such a nice build you have there. The end of your new tube with the tag on it looks like it has the right bend for the vac mod. The stock one on mine has the same bend and a short piece of vac tubing. The tubing & mod darn near plug into each other. Wish I had more help for you.
yuccales is offline   Reply With Quote
Old 01-13-2017, 08:41 AM   #7
James the III
That line looks like it is for a th400 not a th350..
the th400 the modulator valve comes out the side not the back ..
James the III is offline   Reply With Quote
Old 01-13-2017, 10:05 AM   #8
Fakeshemp73
After going back out to the garage last night and messing with it for a few minutes I came to the same conclusion as Boog and packed it back up. I will send it back and try and go with a different company and see if I have better luck or I might just call them up today and see what they have to say about it.
Thanks for the help and comments...
1970 C10
4.5/6 drop from ECE
Mama Tried...
Old 01-13-2017, 10:26 AM   #9
Bigdav160
Bigdav160's Avatar
Here's the one that came out of my truck for reference
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-13-2017, 10:54 AM   #10
Fakeshemp73
Thanks for the picture. That helps.
1970 C10
4.5/6 drop from ECE
Mama Tried...
Old 01-13-2017, 11:07 AM   #11
dfwright
dfwright's Avatar
Here's a shot of how mine was routed before I took it apart.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-13-2017, 04:52 PM   #12
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I think you have it installed upside down?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
