Old 01-12-2017, 07:28 PM   #1
1985 big block 454, California emissions, exhaust manifold tubes, any plugs out there
The previous owner cut and pinched the tubes off, they leak
I'd like to just plug all 8 of em with a plug or bolt, anyone know where to find such a thing? Seems to be an odd ball size...napa has no such thing and that's my only resource in our small town.
Thanks!
Old 01-12-2017, 07:49 PM   #2
100%Chevy
Re: 1985 big block 454, California emissions, exhaust manifold tubes, any plugs out t
I have the same engine.
Someone before me removed the tubes,kept the nuts and put pennies in the holes!
It's still working!
And,I ain't taking them out till it leaks!
Mike.
100%Chevy is offline   Reply With Quote
Old 01-12-2017, 07:52 PM   #3
Old 01-12-2017, 08:51 PM   #4
burban nate
It's still working!
Mike.
If they are still solid copper pennies it'll probably last forever but if they are the copper plated zinc pennies it may not last long. Not sure what year the gov't went to the zinc pennies tho.
Nate
EDIT: just looked it up, all US pennies after 1982 are copper plated zinc.
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 01-13-2017, 01:56 PM   #5
tinydb84
tinydb84's Avatar
I thought they were NPT but could be wrong. I would take the nuts out and weld the holes shut.
David
Instagram: myfabguy
Old 01-13-2017, 05:37 PM   #6
raceman6135
Dino burner
raceman6135's Avatar
They're not an NPT thread because it is not the threads that do the sealing; it is the 45-degree flare that does the sealing. Regardless, when I removed my A.I.R. (Air Injection Reactor) tubes, I used BRASS pipe plugs (common hex head that you can find at auto parts stores, hardware stores, plumbing supply places, etc.). I believe mine used 1/4 inch NPT.
Example:
The reason I used brass plugs is that they will thread in a turn or two, and when you put a socket on them and tighten them down another turn or so, the soft brass will deform and do a good job of plugging the hole in the cast iron manifold, and will not leak.
NOTE: you will have to completely remove the existing leaking tube and tube nut for this to work. If you can't remove the remnants from the previous owner's "modification," I'm not sure what will work, other than maybe welding/brazing the ends of the tubes better than what the other guy did.
raceman6135 is offline   Reply With Quote
