Old 01-13-2017, 10:40 PM   #1
custom10nut
custom10nut's Avatar
Tilt column light hook up?
This question is about my tilt column that I put in my truck.
Where does the little gray wire for the gear indicator hook up?
I know the fiber optic wire hooked to the back of one of the panel lights, but that won't power the bulb in the tilt column.
Am I doing something wrong, or do I just hook it up to a power source controlled by the light switch?
I'm sure there is a right place to hook it up.
custom10nut is offline   Reply With Quote
Old 01-13-2017, 10:58 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Tilt column light hook up?
Connects to the male terminal on the fuse block between "panel lights" and "cluster feed".
FirstOwner69 is offline   Reply With Quote
Old 01-13-2017, 11:59 PM   #3
custom10nut
Awesome, thanks!
