Old 12-11-2016, 10:51 AM   #1
steveb64
steveb64's Avatar
Stepside Tank and Compressor Mounting
Figured out where to mount tanks and a compressor on my stepside. I wanted to leave the space open between the frame rails in the back for a future Boyd's tank. I also wanted to keep everything hidden as much as possible.
I ended up using 2 tanks, 3 gallons each, one on each side. My idea is to just manage my air easily, nothing extreme or constant, for now anyway.
Started working on my manual valve install under the seat and easily accessible with my left hand.
This stuff is fun!
steveb64 is offline   Reply With Quote
Old 12-12-2016, 12:57 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Stepside Tank and Compressor Mounting
i have dual 3 gallon tanks and dual compressors. my tanks are mounted under the stepside fenders behind the tires and my compressors are mounted on the frame.
Willie Makeit is offline   Reply With Quote
Old 12-18-2016, 03:37 PM   #3
68is4me
68is4me's Avatar
Looks good. The step side makes it fun. I am also ruining a Boyd's tank and put my 5 gal tank between the frame behind the fuel tank
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 01-08-2017, 06:47 PM   #4
steveb64
steveb64's Avatar
Completed manual valve install, no more Schrader valves.
Old 01-12-2017, 07:11 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
What is the little round thing and who makes the manual valve?
Old 01-12-2017, 08:15 PM   #6
steveb64
steveb64's Avatar
The round thing is the filtered air intake for the Viair 444C compressor. The valve is made by Air Jaxe, called the FourPlay, used to be Little Larry's.
Old 01-15-2017, 12:47 AM   #7
mehoff400
mmmhhh interesting how do you like the set up? i am looking for a beginners set up i have prior experience with bags
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 01-15-2017, 01:32 AM   #8
steveb64
steveb64's Avatar
Works great, easy to regulate flow with the valves.
