Old 01-14-2017, 10:53 PM   #1
18Z
18Z's Avatar
Clutch Fan
Is there a good aftermarket clutch fan for my 1971 GMC 4X4 with a 350 in it?
18Z is offline   Reply With Quote
Old 01-14-2017, 11:17 PM   #2
hjewell2
hjewell2's Avatar
Re: Clutch Fan
four seasons makes great one look on summit
hjewell2 is offline   Reply With Quote
Old 01-15-2017, 12:07 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Clutch Fan
Quite a few actually.... To be clear, do you need a clutch fan (fan blades), or a fan clutch (what the fan blades attach to)?
Assuming it's the clutch unit, your '71 is probably like my '72 K20. Factory 7-blade fan with a 2 1/2" pitch. If so, it should use a HD clutch like the factory one. HD ones have fins across the front, and standard-duty ones just have a ring of fins around the perimeter.
A few months ago I replaced my leaking OEM fan clutch with one from my local NAPA store. Made in Texas by Four Seasons, NAPA p/n 271303. It's a perfect fit.
Oddly, most aftermarket outlets don't list a HD unit for my truck. We had to look up a mid-to-late Seventies K30 to find the correct HD unit.
Good info here including differences between standard & HD,if you're interested: http://www.haydenauto.com/featured%2...s/content.aspx
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-15-2017, 01:51 AM   #4
18Z
18Z's Avatar
Re: Clutch Fan
I should of been more specific, I need the Fan w/6 or 7 blades that will take a thermal clutch attached to it. I know I can get the clutch itself but can't find the fan.
Old 01-15-2017, 01:53 AM   #5
18Z
18Z's Avatar
Re: Clutch Fan
Stocker, thanks for the NAPA part# number also, I will check that one out.
Old 01-15-2017, 01:55 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Clutch Fan
Forgot to add the Four Seasons part number to the above NAPA clutch I bought.... it's #2747.
- Mike -
RIP El Jay
Old 01-15-2017, 01:59 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Clutch Fan
There's this but it's kinda spendy http://www.speedwaymotors.com/Dynaco...FQ9EfgodlrQB-A
A bit cheaper http://www.classicindustries.com/pro...arts/k193.html
Good luck, I hope ya find one that works for you. Local boneyards all cleaned out?
- Mike -
RIP El Jay
Old 01-15-2017, 02:07 AM   #8
18Z
18Z's Avatar
Re: Clutch Fan
Stocker, Also I think the 4 Seasons part#number is 36956, NAPA uses their own number I think, but I could be wrong.
Old 01-15-2017, 02:10 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Clutch Fan
That's very possible.... I just got the p/n off the box it came in. It also had NAPA p/n 271303.
- Mike -
RIP El Jay
Old 01-15-2017, 02:47 AM   #10
18Z
18Z's Avatar
Re: Clutch Fan
Thanks for the info Stocker!
Old 01-15-2017, 01:37 PM   #11
kelz702
Re: Clutch Fan
I bought this one from Summit a few weeks ago https://m.summitracing.com/parts/der-17118/none/images. I'm happy with it
kelz702 is offline   Reply With Quote
Old 01-15-2017, 01:55 PM   #12
18Z
18Z's Avatar
Re: Clutch Fan
Kelz702, Thanks for the info!
Old 01-15-2017, 02:17 PM   #13
57taskforce
All about them K’s
57taskforce's Avatar
Re: Clutch Fan
OE fans come up for sale on the parts board from time to time as well.
Tyler
Old 02-02-2017, 06:07 PM   #14
joeydurango
joeydurango's Avatar
Re: Clutch Fan
Hey guys, not to hijack this thread, but it's exactly the type of info I'm looking for. Couple questions, especially for you, Stocker, since our trucks are pretty similar:
1) Am I correct in assuming that the stock 7-blade fixed fan will accept a clutch unit? EDIT FOR FUTURE SEARCHES: Nope.
2) Stocker, how far does your fan clutch sit from the radiator? I've read elsewhere that a thermostatic clutch needs to be very close (like only 1-2") to the radiator in order to heat up properly and actually disengage. Want to change out my fixed fan (for HWY MPG) but as you all probably know the 4x4 engine sits further back and I want the clutch to actually work. My fixed fan is several inches from the radiator, essentially sitting just inside the shroud.
Thanks everyone for any info.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
Last edited by joeydurango; 02-02-2017 at 08:08 PM. Reason: Answered my own question
joeydurango is offline   Reply With Quote
Old 02-02-2017, 06:09 PM   #15
demian5
demian5's Avatar
Re: Clutch Fan
http://www.truckandcarshop.com
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-02-2017, 07:14 PM   #16
57taskforce
All about them K’s
Re: Clutch Fan
I don't believe that the 4x4 clutches sit that close to the radiator. Mine doesn't I know that much.
Tyler
Old 02-02-2017, 07:17 PM   #17
joeydurango
Re: Clutch Fan
Thanks for the reply. Kind of figured that too... but then I'm wondering if it actually warms up and disengages as it's supposed to?
Old 02-02-2017, 08:01 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Clutch Fan
My fan sits roughly 7" from the radiator. The important thing is that it is more or less centered in the outlet area of the shroud, like Joey's fixed fan.
The Hayden link in post #3 explains when different type clutches engage / release etc. Not sure just how you'd actually check it, though.... depends on what problems you have, if any.
- Mike -
RIP El Jay
Old 02-02-2017, 08:10 PM   #19
joeydurango
Re: Clutch Fan
Thanks Mike. Since yours apparently works okay I'll go with that Napa clutch PN you used, and decide on a fan to match.
Old 02-02-2017, 09:57 PM   #20
57taskforce
All about them K’s
Re: Clutch Fan
My replacement is a napa as well and it does work.
Tyler
