01-15-2017, 04:10 PM | #1 |
lowered front today
I put 3" lower springs on the front of my truck today. Everything went pretty good except drivers side spring won't stay seated in upper spring pocket when truck is jacked up. Took two floor jacks to get it right, one under cross member and one under lower A-arm then lower at same time to hold spring in place. Anyone else have this problem? I am concerned that every time I jack up truck I will have problems getting spring back in position.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
01-15-2017, 04:21 PM | #2 |
laying low
Re: lowered front today
From what I hear that's common with using the 3" drop spring. 2" stays put. I used 2 1/2" lowered spindles and cut 1 round off the stock springs on mine to get her down about 4 1/2". My springs stay put.
01-15-2017, 04:37 PM | #3 |
Shorter drop shocks or limiting straps would solve the problem.
Romans 10:9 - The Truth |
01-15-2017, 07:04 PM | #4 |
So if I install lowering shocks the coils won't drop out of place when jacked up? I stayed with stock shocks so far but if changing them out will help I will do that.
What are limiting straps and how would they work. Thanks.
01-15-2017, 07:49 PM | #5 |
The springs fall loose when the shocks ARE attached?
01-15-2017, 08:25 PM | #6 |
Yes they do. I do have stock shocks. Driver side is worse than passenger side.
01-15-2017, 08:35 PM | #7 | |
Limiting straps are an offroad deal, but they'll work to limit extension on anything. You can mount them from shock eye to shock eye, or bolt them from the frame to the lower shock eye. You can make your own out of cable or strap, or buy them pre-made in any length. http://www.ruffstuffspecialties.com/catalog/LIMIT.html
01-15-2017, 08:38 PM | #8 |
Have a friend with those short springs and they dont stay put either. Why not use drop spindles and have correct geometry anyway?
01-15-2017, 08:42 PM | #9 |
Don't plan on ever getting airborne. LOL Thanks for the help.
