![]() Join Date: Dec 2012
Firewall steering column mount
Can someone tell me the uses of the attached firewall steering column mounts?
Why they are different? Different year? Auto? Manuel? Tilt? Non tilt? Etc. Thanks
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#2 | |
The Older Generation
Re: Firewall steering column mount
I honestly can't tell you for sure but I would say different years. I guess it could even be different assembly plants. If I can remember I will look at some of my trucks in the morning and see if I can tell. LockDoc
good question? i will look at mine also
![]() Join Date: Jun 2005
The two on the right look the same to me. The one on the left may be for a medium duty truck, judging from the size of the mounting holes?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
All 3 of my '67's, and My '68, are like the one on the left. My two '70's, my '71, and my '72 are all like the ones on the right. LockDoc
Lockdoc, Can you tell me if they are manual or auto or tilt or is it just Year specific?
#7 | |
LockDoc
Which would you use? I do believe the left one will have more adjustment.
#9 | |
Look close at your mast jacket/column housing, if it has one bump on it use one of the ones on the right, if it has two bumps on it use the one on the left. The bumps fit into the one raised area or the two cutouts on the brackets.... LockDoc
interested in learning about this
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
I will be having them powder coated. I will use the one that fits the best. Thanks for the help guys!
So this past weekend I switched my non-tilt automatic column (1972) out for a tilt automatic column (1971 or 72, not sure). My non-tilt column used the bracket on the far right, and my tilt column used the one on the far left.
