Old 01-16-2017, 10:47 PM   #1
KyleSeal
KyleSeal's Avatar
Heater Light?
Tearing apart my heaters control panel and noticed the wiring to my heater light (lights up the Def, Fan and Heat rectangular panel) was cut very very close and I cant crimp back to it. Does anyone sell this piece? ClassicParts doesnt seem to. This is on a standard heater 1970
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 01-16-2017, 10:56 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Heater Light?
Can you post a photo of the part?
Old 01-16-2017, 11:48 PM   #3
custom10nut
custom10nut's Avatar
Re: Heater Light?
I'd have to get under the dash and look, but I think it's lit with a small bulb (1445, 1545?), I'll be under there tomorrow and can confirm. Unless of course one of the experts chimes in before
custom10nut is offline   Reply With Quote
Old 01-16-2017, 11:52 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Heater Light?
The bulb and socket should pull out, it just snaps into the housing....
LockDoc
Leon
Old 01-17-2017, 12:15 AM   #5
KyleSeal
KyleSeal's Avatar
LockDoc
The wiring to it is cut way too short to use. I need a replacement.
Old 01-17-2017, 01:10 AM   #6
dmjlambert
dmjlambert's Avatar
Re: Heater Light?
Here it is in the LMC catalog
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=83
The bulb is supposed to be an 1895 bulb.
Old 01-17-2017, 01:43 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Heater Light?
Local part store should have them. Mine do.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-17-2017, 07:24 PM   #8
scooterpimp
scooterpimp's Avatar
Re: Heater Light?
I have one in my hand with about 7 inches of wire & bulb , you can have it if you want , then can reimburse me on postage if it works out for ya.
scooterpimp is offline   Reply With Quote
Old 01-18-2017, 03:58 AM   #9
Custom/20
Custom/20's Avatar
Re: Heater Light?
I was in that same boat but for mine it was a little different. The wire just broke off of the part that was crimped. What I did was disassemble the plug and slide some heat shrink on the wire and solder it back together.
Custom/20 is offline   Reply With Quote
Old 01-18-2017, 09:07 AM   #10
Fozzdik
Fozzdik's Avatar
Re: Heater Light?
Find a standard socket (old style) like an 1157 brake light/turn signal, the older ones have the brass contact crimped onto the wire, they will usually pull right out the front of the socket...
Fozzdik is offline   Reply With Quote
classic parts, heater, parts
