Old 12-31-2016, 09:56 AM   #1
358nivlac
Transfer Case Shifter Wobble
I have a 72 Jimmy and the transfer case shifter wobbles side-to-side.
Presumably there should be a spring or something to keep it stable.
Can anyone tell me what should be there and if possible post a photo?
Thanks!
358nivlac is offline   Reply With Quote
Old 12-31-2016, 11:11 AM   #2
52napco
Re: Transfer Case Shifter Wobble
No spring.your bolt and or shifter is just worn. If its lifted your driveshaft
Angle could be wrong causing it to vibtate.
52napco is offline   Reply With Quote
Old 12-31-2016, 05:25 PM   #3
jaros44sr
jaros44sr's Avatar
[url=https://flic.kr/p/QpsjkW]
It is only held in place with a large pivot bolt, maybe your bolt is backing out, can't imagine shifter bolt or shifters wearing into an egg shape to allow wobble, but these trucks are over 45 years old. Lack of grease could cause it
[url=https://flic.kr/p/P9qons]
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 01-01-2017, 09:47 AM   #4
68panelman
68panelman's Avatar
I had one do that about 20 yrs ago, and I put large plastic washers from a plumbing supply between the bolt and divorce mount and worked great. Mine was a chinging and a rattling too.
68panelman is offline   Reply With Quote
Old 01-01-2017, 01:36 PM   #5
358nivlac
Thank you for all the info and photos!
I will have a closer look and try to source a new bolt.
I love this forum!
Old 01-01-2017, 04:06 PM   #6
JimH2828
I worked on my 70 Blazer NP205 a while ago and learned there were 2 size bolts used over the years. In my case I needed the narrower 7/16-14 thread bolt.
1969-70 used 7/16-14 x 2-3/4 bolt with 5/8 head
Size:  94.4 KB Name:  Capture2.jpg
1971-72 used 9/16-12 x 2-3/4 bolt with 15/16 head
- the pic above from jaros44sr is it.
- I may have one, shout if you want me to look, they usually go for around $50
-Jim
JimH2828 is offline   Reply With Quote
Old 01-02-2017, 08:31 AM   #7
52napco
69 and 70 utilized the 221 case and in 1971 they went to the 205
Old 01-02-2017, 11:49 AM   #8
hemi43
hemi43's Avatar
My 70 has the 205.
Also, my shifter did not have the split bushings shown above. I was able to remove most of the slop with a large diameter washer.
hemi43 is online now   Reply With Quote
Old 01-02-2017, 04:11 PM   #9
358nivlac
Thanks. I am thinking about maybe going to a dual stick.
I installed a Lokar shifter on the floor and was thinking about making a console - so now would be the time for a twin stick!
Old 01-02-2017, 06:22 PM   #10
jaros44sr
jaros44sr's Avatar
Ok, I want to install a Lokar shifter like yours, mounted on the tail shaft, Got some more pics. If you want my advice on the twin stick PM me. I don't want to give negative advice about a companies product on the board. I have both
I had the same problem with making the two shifters look right together, and I think your mount for the Lokar may be the answer
If you find Stephan Jarvis's number please pm me
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2017, 06:30 PM   #11
358nivlac
Sorry - don't have many photos and the truck is tucked away for the winter.
I got the nostalga version of the lokar shifter - it has a funky bend in it! I also got the matching bott trim ring that includes an LED display to show what gear its in. Super easy to install.
If I get serious about the twin stick idea I'll pm you.
Old 01-02-2017, 06:35 PM   #12
jaros44sr
jaros44sr's Avatar
Thanks, I was worried it wouldn't clear the transfer case shifter, I have the 10" shifter from Lokar and was thinking of going to the 8"
It looks like if you move the shifter to the rear mount, both would line up. Am I correct?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2017, 06:37 PM   #13
358nivlac
Couple more photos of the truck.
Old 01-02-2017, 06:43 PM   #14
358nivlac
Jaross44SR - they would be close if you used the rear mount.
I cut about an 1 1/2 inched out of the length of the transfer case shifter to make it sit a little lower and a little more towards the passenger side.
I had a B&M pistol grip shifter left over from another project and put it on the transfer case shifter.
Old 01-02-2017, 06:46 PM   #15
jaros44sr
jaros44sr's Avatar
Dude, that thing is sweet, you should be out running around in the snow LOL
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2017, 07:26 PM   #16
358nivlac
It would be fun in the snow!
Problem is they use a silly amount of salt on the roads up here!
Old 01-03-2017, 11:05 AM   #17
jaros44sr
jaros44sr's Avatar
salt sucs, I ride upstate NY, and half the bodies are gone up there, somehow, still passes state inspection
What shifter mount did you buy....trans mount or tail shaft mount?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-03-2017, 11:32 AM   #18
358nivlac
I bought the trans mount - I wanted the transmission shifter to sit ahead of the transfer case shifter.
Old 01-03-2017, 03:19 PM   #19
hemi43
hemi43's Avatar
Same here near Oshawa. Mine is put away till spring. I bought my truck from Ottawa in 2015. You may have seen it around.
Old 01-03-2017, 06:28 PM   #20
358nivlac
Didn't see your truck.
I'm in the west end and have only seen 1 blazer, a bright orange 1970.
I bought mine from a gentleman in Chicago in 2012.
Drove through Oshawa over Christmas - I am originally from Kitchener and drove down to visit.
Old 01-13-2017, 12:00 PM   #21
jaros44sr
jaros44sr's Avatar
Originally Posted by hemi43 View Post
My 70 has the 205.
Hemi, where did you locate that large washer, between the shifter and the mount or between head of bolt and shifter?
My twin stix wobble, and thinking of turning down some sort of plastic, between both shifters, but didn't know if I should put it between all joints
Why don't they put the salt away, and let us fend for ourselves
SAFETY FIRST
AS usual, off topic
Jim
Old 01-13-2017, 12:07 PM   #22
jaros44sr
jaros44sr's Avatar
I noticed that you marked up your trans mount plate, I'm guessing you had to slot mount to attach rear mount to adapter. Mine doesn't seem to line up with holes in adapter. I was thinking of modifying rear mount to allow it to fit to adapter by grinding mount
SAFETY FIRST
AS usual, off topic
Jim
Old 01-15-2017, 08:34 PM   #23
358nivlac
Sorry for the delayed response - I have been out of town.
Yes! You have a good eye. In order to get the shifter where I wanted it I cut a slot in rear holes to mount it.
Old 01-17-2017, 12:16 PM   #24
jaros44sr
jaros44sr's Avatar
Thanks for your time, eyes may be the only part working on me, comes from combing parts catalogs for 50 years LOL
What happened to cinders or sand for road traction
SAFETY FIRST
AS usual, off topic
Jim
Old 01-17-2017, 04:41 PM   #25
358nivlac
Exactly - bring back sand! And perhaps plough the streets occasionally...
