08-06-2012, 08:57 PM | #1 |
Where can I get a good rear end for A 62'
I have a 62' with a 350 in it right now i plan on getting a new transmission sometime and want to change the rear gears but I dont know that much about ratios and i dont know if I can just change the gears out or if i will have to get a whole new rear end. I want something that will make my truck badass. I dont care if its out of a car at the junkyard i just would like to know what car or where i could find a decent rear end?
thanks Jamel |
08-06-2012, 09:02 PM | #2 |
Re: Where can I get a good rear end for A 62'
theres a stock 61 shortbed with a stock rearend in it at merced pick n pull. Only a 60-62 will fit right I think...
08-06-2012, 11:34 PM | #3 |
60-66 Nut
Is your truck a Chevy or GMC? A C10 or C20? I assume you are looking for higher gears for lower cruising rpm's?
08-07-2012, 12:32 AM | #4 | |
Posted via Mobile Device |
08-07-2012, 12:42 AM | #5 |
60-66 Nut
A '62 Chevy C10 is most likely going to have a Eaton HO32 differential. The most common gear ratio in those is 3.90. There used to be 3.36 gears available for those differentials, but I don't think they are available any longer. A fairly good all around rear gear is the 3.42 gears. To be able to have those gears you will need to change the entire differential to either a '63-'82 truck 12 bolt, or a '80-'87 truck 8.5" 10 bolt. The late '70 to '87 differentials are going to be 1.5" wider than your current differential. and of course the '71 and up C10's will have the 5x5 wheel bolt pattern. Regardless of which differential you choose, there will be a certain amount of cutting, welding and fabrication involved. You can also go one step further and install an overdrive trans for even more of a decrease in highway rpm's. If you feel the need for increased accelleration, just pull it down a gear or two.
08-07-2012, 09:43 AM | #6 |
So if I went with a later rear end say like 70's to 80's I would have to weld in the. Ew gear box, or if I find a complete rear end from like a late 70's truck I couldn't just swap it out? I mean grated I know it won't line up with the old rear end and I may have to get a new drive shaft but is there no way just to swap it out?
08-07-2012, 10:51 AM | #7 |
"Where were you in '62?"
What's your estimated HP/TQ on that 350? What type of trans you are using?
8.8 Rear End that will mount up to a 1962 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=326263 Gear Ratio Calculating - Not bad info: http://www.chevyhiperformance.com/te...ing/index.html If you wanna go 9": Everything you've ever wanted to know about Ford 9 Inch Differentials! http://67-72chevytrucks.com/vboard/s...d.php?t=454229 For the rice burners....Priceless
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
08-07-2012, 12:43 PM | #8 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
08-07-2012, 02:23 PM | #9 |
Do you think that would fit on my c10?
08-07-2012, 02:50 PM | #10 |
The housing width is 54.25" with the axle stand out, it is just shy of 60", so it should fit nicely, especially if you want to fit a wider and deeper wheel combo. I acquired it to use on a customer C-10 project, but he sold it before we could use it.
08-07-2012, 02:54 PM | #11 |
Hell yeah man if your selling it for 10$ and it's in good condition I don't think I could pass it up
08-07-2012, 05:24 PM | #12 |
Senior Car Nut
the 8.2 is not a "bolt-in" unless vin63 has already modified it.
Larry |
01-17-2017, 01:20 AM | #13 |
Does anyone know the measurement between the trailing arm mounts on a 62 C10?
01-17-2017, 02:03 PM | #14 |
Just for info Yukon gear still make the ho-32 3.38 ring and pinion.
1961 chevy K10 my build is------------61K10 build |
