01-13-2017, 11:49 AM | #1 |
60-66 CREW CAB HINGES need pictures
Anyone have pictures of a Crew Cab rear door hinge ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-13-2017, 01:17 PM | #2 |
Re: 60-66 CREW CAB HINGES need pictures
Jon; do you want the protruding ones or the hidden ones?
ron |
01-13-2017, 01:33 PM | #3 |
internal hinges. I did look at these close at the time and thet were the same as the front door ones and actually I have the set for both doors as they were like new. don't think those doors ever got used much. sill plates were hardly touched
should have more pics if you need another view; just have to dig a little for them ron |
01-13-2017, 03:18 PM | #4 |
SAVING ONE TRUCK AT A TIME
Here is a pic of the hinges on my crew. Hope this helps.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
01-13-2017, 07:51 PM | #5 |
Junior Member
I can try to get some off my crew tomorrow .
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
01-14-2017, 01:11 AM | #6 |
60-66 Nut
I wonder if those hinges may be the same ones used on the Suburban/Panel cargo doors?
01-14-2017, 06:00 AM | #7 |
whats you building jon ? i got those ones that stick out on my crew cab ! its a "stageway " if you find any extra ones ??? i need a set for my left rear door ! its there hung as a non opening door ! would be nice to use it -as a functioning door ! might have to see if i can reverse fab some -never could find what they was made for originally ??? see ya -take care !!
01-14-2017, 01:57 PM | #8 |
Do you have pics or a build thread wahl4m? Did you see my post of my Stageway brochure?
01-16-2017, 06:28 PM | #9 |
1961 crewcab
some of mine:
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-16-2017, 06:33 PM | #10 |
1961 crewcab
more shots:
01-16-2017, 06:38 PM | #11 |
1961 crewcab
the last couple shots I have: would be real curious to figure out where they were sourced from, I have tried looking on quite a few gm vehicles from the late 50's/early 60's but have not seen a source as a gm part. I did not see a part # anywhere on the part I took apart, but I only pulled the hinge from the pillar, not the door.
01-16-2017, 06:54 PM | #12 |
1961 crewcab
this 3 door crew had a different kind of hinge- notice the 4 screws : it is also a 61
01-17-2017, 05:03 PM | #13 |
jonz customs -how is your crew cab coming along ??i need to see somebody getting something done on there c cab to inspire me to do something !!! thanks mi8ke
