Re: Dash Cluster
If the truck harness is butchered, you may have to hook it back up like it was or fix the problems. A new circuit board may not fix it.
Oh and add a ground wire between the cluster bolt above the speedo and the body of the truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Dash Cluster
Demian5 I installed a new wiring harness. Just tying to button everything up . So looks like i need to replace the circuit board to make it work correctly.
