Old 06-09-2016, 10:13 AM   #51
Wide Open
Re: Re-Bertha: 71 C20 to 72 K20
Originally Posted by PeterHall View Post
I think its a 60E. I may have wrote 80E earlier. I have no idea what adapter was used. We dropped off our old transmission as a core and the np205 and asked the transmission shop to make it worked with the new 60E. The adapter bolts between the transfer case and the transmission, which was good in our case because it pushed the big block away from the firewall. I can snap a picture when Im in front of the truck again
OK thanks. Advance Adapters has one that looks nice but is a little pricey at first look but it does include a new input shaft and the larger front bearing and a bunch of other stuff. I'm always on the lookout for options though especially with people who've already been there done that.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 06-09-2016, 03:52 PM   #52
tommys72
tommys72's Avatar
Awesome work! Ill hang around for updates
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 06-09-2016, 09:04 PM   #53
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sorry to hear about the original truck but you guys are doing great work on the new truck! Nice painting too!
Ryan
1969 Chevy milk truck
Old 06-17-2016, 11:52 AM   #54
PeterHall
Here's whats on ours. Certainly looks like an advance adapter. I can't tell you how well it works yet!
https://www.summitracing.com/parts/a...0405/overview/
PeterHall is offline   Reply With Quote
Old 06-17-2016, 01:37 PM   #55
Wide Open
Cool thanks.
This is the one I'll likely end up using -
http://www.advanceadapters.com/produ...ransfer-cases/
1972 K10
2002 Z06
2007 Escalade
Old 06-30-2016, 10:20 AM   #56
PeterHall
Dad has been working on things in the cab. We got the brake pedal in and the system bled. Parking brake in. Fuse block in.
I painted the inside of the fenders black with some rust bullet we had left over. Then finally painted them.
Old 07-12-2016, 03:25 PM   #57
PeterHall
Starting to look like a truck. I think I'm going to the paint the grill gloss black. There are some chunks missing out of it that will look out of place if it was polshed. It will also blend in with the new bixenon headlights.
We installed bilsteins 5100's while we had easy access to the front and rear. Hopefully we'll get the wheel liners and fenders installed in the coming week.
My dad had a friend TIG weld a different gas cap on and a vent. Hopefully this works.
Old 07-12-2016, 05:11 PM   #58
Dieselwrencher
Nice work! I like the new fill neck and the bilsteins!
Ryan
Old 09-04-2016, 12:15 AM   #59
PeterHall
So not much to update. Dad has done a lot of the wiring harness, the truck is now "turn-key". We had a heck of timing burping the radiator as it had a tendency boil over and spew fluid everywhere. Enjoy this short video of it running open headers. Timing still has to get dialed in.
https://youtu.be/vgWKycFK3-c
We also got distracted and bought a cheap 1972 Jeep wagoneer
Old 09-13-2016, 11:21 PM   #60
PeterHall
Worked more on the exhuast. Got the cutout valves in and need to finish up the mufflers. Dad has almost finished wiring everything and now is working on the small things like switches.
We were also able to reuse the stock shift linkage and mate it with the new transmission.
Old 10-18-2016, 12:08 AM   #61
PeterHall
Piece by piece its slowly coming together.
Old 11-09-2016, 11:36 AM   #62
PeterHall
We got the front and back glass in. Man that job sucked. We couldn't find anyone to come out and do it so we did it ourselves.
Old 11-09-2016, 11:44 AM   #63
Wide Open
Looking good!
1972 K10
2002 Z06
2007 Escalade
Old 11-09-2016, 05:35 PM   #64
Dieselwrencher
The engine sounds nice! I'm really jealous on how you can leave your stuff stored out side for so long! I've got to put 2 cut outs like those on a diesel truck. I hope they can with stand some heat.
Ryan
Old 12-04-2016, 11:09 PM   #65
PeterHall
We tried a pop up tent outside but the wind kept knocking it over! So a car cover has actually kept everything nice and clean. That and lots of paint is keeping things rust free.
We got the led markers and headlights installed!
Old 12-06-2016, 01:45 AM   #66
mcmlxix
Collector of Projects
mcmlxix's Avatar
This looks great! Custom but not obvious.
Rich
1972 K5 Blazer CST Click HERE
Old 01-18-2017, 01:18 AM   #67
PeterHall
Almost finished blocking out the doors. We've been driving the truck around to work out a few kinks. Hoping to bring it to a local shop to have the vintage air installed soon.
Does anyone have suspension upgrades they recommend? The front end feels loose and could use some help
Old 01-18-2017, 06:59 AM   #68
GR8-68
GR8-68's Avatar
Very nice work, look forward to seeing the end results
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
