Old 01-20-2017, 10:30 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Found Temp sender that works with Original Gauge
NAPA Ecklin TS6666 sender works perfect with Original Gauge. You can get the 1/8 pipe adapter for the LS at Speedway.com . We hooked a real time scan to it and ran it for ~1/2 hour.
Sender is at the back of Passenger side head
Pics tell the story
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-21-2017, 07:34 AM   #2
solidaxel
solidaxel's Avatar
Re: Found Temp sender that works with Original Gauge
Am I reading the gauge to be 201* in that position ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-21-2017, 11:36 AM   #3
1970 CST Short Wide
Senior Moment
Originally Posted by solidaxel View Post
am i reading the gauge to be 201* in that position ?
yes, which would be very close to normal for an LS
Pittsburg Ca
94565
Old 01-21-2017, 09:49 PM   #4
Dustytrix
I am glad someone finally got something simple to work, good job.
Dustytrix is offline   Reply With Quote
Old 01-21-2017, 09:58 PM   #5
1970 CST Short Wide
Senior Moment
I need to give a BIG THANKS to the guy at NAPA who took the time to help me look though his books to come up with this. Wish I could remember his name. Will be going back to say thanks for sure
Steve
Pittsburg Ca
94565
Old 01-22-2017, 04:28 PM   #6
cagodinez
cagodinez's Avatar
Would this work on my truck? 1978 C10, gathering parts for my 2002 5.3/4L60e swap.
cagodinez is offline   Reply With Quote
Old 01-22-2017, 06:04 PM   #7
Willie Makeit
Willie Makeit's Avatar
the simplest solution would be to drill & tap the head and use the original sending unit. plus, the gauge would read correctly too.
Willie Makeit is offline   Reply With Quote
Old 01-22-2017, 11:22 PM   #8
1970 CST Short Wide
Senior Moment
Why take the chance of messing up drilling and taping. I'm a machinist and would have no problem. This is simply screw it in, most everybody can do that and the gauge IS correct
Just my 2c
Pittsburg Ca
94565
Old 01-22-2017, 11:27 PM   #9
1970 CST Short Wide
Senior Moment
It depends on what Ohm's your gauge works at. I want to say that in my search I saw an 1/8 pipe sender for a late 70's . All you would need is the metric adapter from Speedway.com. Sorry I don't have the number but shouldn't be hard to find
Good luck
Pittsburg Ca
94565
Old 01-23-2017, 09:00 AM   #10
Willie Makeit
Just my 2c
If the picture you posted is what you consider "correct" and you're happy, then I suppose that's ok.
Old 01-24-2017, 01:38 AM   #11
1970 CST Short Wide
Senior Moment
YES I consider this correct. This is where the gauge would set with a small block or BB at 180 degrees F. An LS runs at ~210 F so again YES this would be correct
And YES I'm happy, are you?? KIS keep it simple
Pittsburg Ca
94565
Old 01-24-2017, 07:34 AM   #12
72MARIO
72MARIO's Avatar
Thanks for taking the time to come.up with the correct sending unit. Its great to have a bolt in option..
We all know that a drill and tap can make the stock sender fit. I personally didn't want to chance messing up the head.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-26-2017, 01:37 AM   #13
1970 CST Short Wide
Senior Moment
Especially if you try to do it in the truck. No fuss no muss this way
Pittsburg Ca
94565
Old 01-31-2017, 06:49 PM   #14
crakarjax
crakarjax's Avatar
I'd like a sender that puts the needle vertical at operating temp. Any idea what voltage/resistance that would be at? I thought my gauge or sender was funky because of the placement all this time, as that's a strange spot to place the needle. I guess having that speedway part opens up some options (have the part number by chance?).
Actually I guess you could always just add the correct resistance in series or parallel inline with the sender wire to put it exactly where you need it, regardless of the sender used.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-31-2017, 10:25 PM   #15
1970 CST Short Wide
Senior Moment
Because an LS runs at ~210 I like where the gauge sets, to each his own on that. I would have to look up the Speedway adapter #. It's easy to find on Speedway.com
Pittsburg Ca
94565
Old 02-01-2017, 12:36 PM   #16
binford
Active Member
Speedway link to adapter
ECHLIN TS6666 1633.2 Ohms @100° 156.6 Ohms @ 220°
I believe the stock gauge is 80 ohms being hot and 900 being cold.
link to Napa catalog book
The TS6655 on page 31 should put the gauge a bit more in the middle. I will buy and test one, some day project engine is still sitting next to the truck
with 1087 Ohms @100° and 111 Ohms @220°
Awesome find 1970 CTS Short Wide
binford is offline   Reply With Quote
Old 02-01-2017, 10:34 PM   #17
1970 CST Short Wide
Senior Moment
Great info. It just takes some time and effort to get what you need
Pittsburg Ca
94565
Old 01-08-2018, 09:32 AM   #18
elf w/capital T
You are the man! Ive got NVU gauges and trying to find the adapter to use their sender, Your post definitely helped!!
elf w/capital T is offline   Reply With Quote
Old 05-17-2018, 09:19 AM   #19
DaHos
DaHos's Avatar
Auto Meter 2277 Adapter
Note: I.D. of this adapter where the sender probe will go through is .309 and would require drilling to approximately 5/16" or .312 for a Stewart Warner sender to pass through.
TS6666 WILL NOT CLEAR center bore (Must drill !)
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 05-17-2018, 10:17 AM   #20
davepl
davepl's Avatar
FWIW here's a graph of the stock sender. If someone wanted to compare it to this one, that'd be handy data!
Somewhere I have a graph I actually plotted on my own in the kitchen with a thermometer and my own sender...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-17-2018, 01:57 PM   #21
Jason Banks
Jason Banks's Avatar
I found a pdf of an Eichlin - Engine Management Reference Guide and these are the specs it had listed for the TS6666
TS6666 1 threaded stud
156.6Ω@220°F, 1633.2Ω @100°F
1/8 x 27 Dryseal
Jason Banks is online now   Reply With Quote
Old 05-21-2018, 09:34 PM   #22
88Stanger
88Stanger's Avatar
thanks for the info!!!
88Stanger is offline   Reply With Quote
