Old 01-23-2017, 12:20 AM   #1
Dads64
Need a little help
Does anyone know if the measurement between these two mounts are the same on all the 64-66 trucks? The red cab is a 66 and the other a 64 but the distance in different from one cab to the other and I am not sure it should be. Need to figure it out before I try to use the 66 cab as a replacement for the 64.
Thanks all,
Jay
Dads64 is offline   Reply With Quote
Old 01-23-2017, 09:13 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Need a little help
Thanks all,
Jay
You can easily interchange 64-66 cabs. They're all the same.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-23-2017, 09:15 PM   #3
LostMy65
LostMy65's Avatar
If you're finding a difference, that's really, really unusual. There shouldn't be any.
Old 01-24-2017, 12:30 AM   #4
Captainfab
60-66 Nut
The '64-'66 C10,20 & 30 cabs are identical. And as far as the inner fender mounts, the '60-'63's are the same dimension in that respect
Old 01-24-2017, 11:42 AM   #5
Dads64
Thanks guys, I will get out there and measure it again. I don't remember the numbers now but they were about an inch or so off if I recall. I know the '66 had front end damage but can't/couldn't see any damage to the cab at all.
Old 02-01-2017, 06:21 PM   #6
Dads64
So I finally got out there and sure enough they are right at an inch different.
Not sure why the pics are sideways, sorry about that.
Old 02-02-2017, 07:37 AM   #7
PGSigns
PGSigns's Avatar
Can you take pictures looking straight on at the firewall? Being able to see both from this view may help see what is going on.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-21-2017, 10:27 PM   #8
Dads64
Best I could get without laying the red one back down
Old 02-22-2017, 07:40 AM   #9
PGSigns
PGSigns's Avatar
Looks like they have both been moved around some over the years or its just the difference between 2 assembly plants. I would not have a problem with proceeding on. It is just the support for the lower corner of the inner fender and if it needs a tweek during assembly a wack with a rubber mallet will make the adjustment.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-22-2017, 11:10 AM   #10
paulspickupparts
Did both cabs come off a pickup? Or did one come off a pickup and the other off a C60 or larger truck? Usually the floor and trans cover is a giveaway . Trying to look at the weathering of the inner fenders to see if it is the same width as big trucks also took a different inner fender. Too hard to tell in the photo
paulspickupparts is offline   Reply With Quote
