Old 01-16-2017, 05:14 PM   #1
81square
Stock height or small lift 4x4s tire size and lift
I have a 1981 stock longbed with negative front springs, is that normal or are they just extremely worn? I would like to put 33x12.50x15 tires on it with little to no lift, I'm going for the beefy, but stock look. Let me see some picks of your trucks and give info about lift and tire size! and brand of lift and how it rides please. Pic of my truck below
81square is offline   Reply With Quote
Old 01-16-2017, 06:41 PM   #2
Jaysonb
Jaysonb's Avatar
Re: Stock height or small lift 4x4s tire size and lift
My 80 k10 Has 33/12.5/15s on it. I have a 2" rough country lift on it, it rides better than it did with old worn out springs, and old worn out shocks on it.
Jaysonb is offline   Reply With Quote
Old 01-16-2017, 06:53 PM   #3
kwmech
33s will not fit on the front with stock negative springs. They will be real tight on the rear also. 31s will fit on the front----barely. You could put a 3 leaf pack on the front and it will pick it up about 1-1/2-2''. Then you could put a 2'' block on the rear. I'm working through the logistics of this on my 91 suburban at the moment
Old 01-16-2017, 07:11 PM   #4
b454rat
Depends on offset of wheels. Buddy has mid 80s that is all stock and is running 33s on 8" rally's. Its close but fits/clears. Normally at least a 2" lift is enough to clear.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-16-2017, 09:35 PM   #5
cochino12
It followed me home?
cochino12's Avatar
295 75 16's ~ 33", newer factory k20 springs zero rubbing
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-18-2017, 05:51 PM   #6
81square
Nice trucks guys!
Old 01-18-2017, 05:53 PM   #7
81square
Your truck looks great! Thats about exactly what I'm looking for, Does that have blocks in the rear or springs?
Old 01-18-2017, 07:00 PM   #8
vht
Cochino12, if mine were a 3/4 ton, that is the wheels I'd have on it, the rallies and your factory alum wheels you have are the best looking wheels going.
vht is offline   Reply With Quote
Old 01-18-2017, 07:10 PM   #9
Jaysonb
Jaysonb's Avatar
Thanks man. Yes it has blocks in rear.
Old 01-18-2017, 07:29 PM   #10
Tom
driving is in my blood
Tom's Avatar
I'm a lowered guy, but I feel this guy gets it.
https://www.youtube.com/watch?v=r85zDhRpRTU
Old 01-21-2017, 07:10 PM   #11
81square
Jayson, when you installed the 2 inch Rough Country lift how much did it actually lift your truck? Was it 2 inches? Or a little more or little less? Thanks
Old 01-23-2017, 07:26 PM   #12
81square
Nice truck! Whats the actual tire size on those?
Old 01-24-2017, 01:10 PM   #13
daddyjeep
daddyjeep's Avatar
Um....It says the actual tire size above the pic.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 01-24-2017, 01:23 PM   #14
SCOTI
SCOTI's Avatar
Yep. One can't really provide much more detailed info than what was posted.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-24-2017, 04:45 PM   #15
NorCalAnthony
You shouldn't have any issues running 33's without a lift, that's what I ran on my '78 K5. Here's a picture of my current project:
It's an '84 diesel K5 with 275/70R18 tires which are 33.2" according to the manufacturer's website. The truck is otherwise completely stock and I haven't had any signs of rubbing.
NorCalAnthony is offline   Reply With Quote
2 inch lift, 33s, 4x4
