Old 01-25-2017, 06:22 AM   #1076
Re: A 15 year old's project. Rusty 62 stepside
Very nice looking work. Your idea sounds good to me since they are run with a single belt in a serpentine system.
Old 01-25-2017, 10:42 AM   #1077
scoot_mcgrute
That bracket turned out great! I bet you'll be just fine running a single belt for the whole system and it looks like you've got room to mount a simple idler/tensioner pulley later if needed.
Keep it up!
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 01-25-2017, 11:43 AM   #1078
TJ's Chevy
TJ's Chevy's Avatar
Great job man!
Old 01-25-2017, 07:59 PM   #1079
Advanced Design
Advanced Design's Avatar
Excellent work on your bracket! Well done!
Advanced Design is offline   Reply With Quote
Old 01-25-2017, 10:17 PM   #1080
65sub
65sub's Avatar
Nice job on the bracket. Looks very professional.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-25-2017, 11:15 PM   #1081
62stepside longbox
62stepside longbox's Avatar
Originally Posted by Grizz1963 View Post
Your skills really are coming along in leaps and bounds mate.
Doors look great.
Thanks rian, metalwork is just one of those things that I have such pride in doing.
Thanks bill, my thoughts exactly.
Keep it up!
Thanks Scott, that is exactly what I thought, I don't think I'll need the idler pulley but I can always add it if I have to.
Originally Posted by TJ's Chevy View Post
Great job man!
Thanks tj
Thanks Doug
Thanks Dale, but I'm far from professional, I just really took my time and put lots of effort into this piece.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 01-26-2017, 11:19 PM   #1082
62stepside longbox
Today I worked on making the adjustment arm. I welded these two together.
Old 01-26-2017, 11:19 PM   #1083
62stepside longbox
And smoothed it out
Old 01-26-2017, 11:21 PM   #1084
62stepside longbox
Then bent this little jog into the piece so it lines up correctly, then drilled a hole through both pieces and put a bolt through.
Old 01-26-2017, 11:22 PM   #1085
62stepside longbox
Here it is all together
Old 01-26-2017, 11:24 PM   #1086
62stepside longbox
Here is the pump adjusted all the way in.
Old 01-26-2017, 11:25 PM   #1087
62stepside longbox
And here it is adjusted all the way out. Power steering pump Bracket is now completely finished.
Old 01-27-2017, 12:22 AM   #1088
Classic v6 GMC's
Classic v6 GMC's's Avatar
Bracket and arm looks good!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 01-27-2017, 11:54 PM   #1089
62stepside longbox
Thanks!
Today I got both the coil springs installed and then torqued the lower ball joints to spec.
Old 01-27-2017, 11:56 PM   #1090
62stepside longbox
I was then able to put the wheels on and put the truck back on the ground for the first time in months.
Old 01-27-2017, 11:58 PM   #1091
62stepside longbox
And since I was already outside I just decided to drill out the plastic pins and separate the collapsable steering shaft.
Old 01-28-2017, 10:42 AM   #1092
TJ's Chevy
TJ's Chevy's Avatar
Bracket turned out great.
Old 01-28-2017, 10:43 AM   #1093
62 Barnfind
62 Barnfind's Avatar
Nice job! I might have to get you to make me one for my truck!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-28-2017, 01:11 PM   #1094
Old 01-28-2017, 09:38 PM   #1095
62stepside longbox
Thanks Tj
Thanks John, I'm actually making another one for Steve Hawkins on the Facebook group, so if you're interested we can talk about it.
Thanks bill
Old 02-05-2017, 05:36 PM   #1096
62stepside longbox
Well about a week ago the temperature dropped and now we're down to -10 celcius with almost one foot of snow on the ground, but I've still been making progress
Old 02-05-2017, 05:37 PM   #1097
62stepside longbox
I started with working on getting the framerail near the steering box welded back in place, so first I tacked it up
Old 02-05-2017, 05:39 PM   #1098
62stepside longbox
Then I fully welded it up and ground it down smooth with a flap disk, it actually looks much nicer than the factory weld seam which can be seen to the far left
Old 02-05-2017, 05:46 PM   #1099
62stepside longbox
I also went to the hardware store and picked up some bolts that are the correct length, the steering box then got bolted in place for the second last time
Old 02-05-2017, 05:48 PM   #1100
62stepside longbox
I then cut the pre-existing solid shaft to the correct length
