Old 01-26-2017, 06:09 AM   #76
Desert1957
Desert1957's Avatar
Re: 49, bagged, 6.0, patina, the works
Originally Posted by 84blaze View Post
If you want a quality steering set up I'd recommend the Little Shop MFG No-toe kit.
S10 NO NOTCH / NO TOE STEERING SYSTEM
I'm running it on my static S10 Blazer and Bagged 49 3100 on S10 chassis. It's a great piece.
Curious what advantages this setup has? Is it a clearance issue or fixing a bump steer problem?
Thanks for the link...
Desert
Desert1957 is offline   Reply With Quote
Old 01-26-2017, 09:49 AM   #77
Dave_The_BMXER
I think bumpsteer and toe correction is the big advantage. However I couldn't figure out if it was needed with reasonable sized wheels.
I found out about it literally right after my front end arrived (of course) but since I'm on a clipped AD frame and to lay running board actually doesn't max out the suspension I'm going to hope it all sort of works itself out in the wash....
Dave_The_BMXER is offline   Reply With Quote
Old 01-26-2017, 07:06 PM   #78
84blaze
Only needs 16" Wheels
84blaze is offline   Reply With Quote
Old 01-26-2017, 07:07 PM   #79
84blaze
It fixes bump steer and toe in/out issues throughout travel. It also eliminates the need to notch for tie rods.
Old 01-27-2017, 08:23 AM   #80
Desert1957
Desert1957's Avatar
OK, Good to know when I finally start my project.
Desert
Old 01-27-2017, 02:50 PM   #81
gigamanx
Subscribed! Any reason you went with the 3 link over the 4 link rear from Thorbros? I was considering the same but wasn't sure of the difference between the two.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 01-29-2017, 07:17 PM   #82
NickL
Originally Posted by HULK64 View Post
I was planning on running the Proforged S10 steering setup- but I am running drop spindles and close to the same drop setup as you. What's the deal with notchless tie rods? Are they necessary with drop spindles?
Everyone has pretty much nailed it. Clearance/to help with bumpsteer. Some updates:
Heres a photo. This is without the motor in the truck and an undersized tire. So you can imagine what it will look like with a larger tire and weight on the frame.
Injectors re-oringed/cleaned. Intake manifold assembled and back on with a new valley pan gasket and knock sensors. S10V8.com 1 5/8 short tubes on.
New water pump, steering box, idler arm, centerlink. Just waiting for my MMW tie rods.
Again but showing the new Speedway GM metric tubular uppers
Took some measurements and decided the 69 Mustang EFI tank from Tanks Inc. would work great. Fabbed some basic mounts and got it in today. Just need to bolt it up and trim the front lip a bit to clear the shocks when aired all the way up.
I'll install the pump tomorrow but am going to wait to run the lines/corvette FPR until after boxing the frame.
NickL is offline   Reply With Quote
Old 01-29-2017, 10:43 PM   #83
youngrodder
youngrodder's Avatar
Nice progress...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-29-2017, 11:06 PM   #84
84blaze
Thats the exact tank I just bookmarked a couple days ago. What do you plan to do for the fill neck? Flexible rubber hose?
Old 01-30-2017, 04:21 AM   #85
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool build!
ChuckDriver is offline   Reply With Quote
Old 01-30-2017, 01:42 PM   #86
NickL
No real reason other than I can't remember them offering a bolt on 4-link back then. Maybe they did haha, been quite some time.
Old 01-30-2017, 01:46 PM   #87
NickL
It will depend on whether I make the bed floor lift or not. If I do, ill keep the bed floor untouched and have a short filler neck that'll be hidden under the floor and accessible once the bed floor is lifted.
If I don't, i'll probably graft a fuel door into the bed floor and use flexible rubber hose up to it.
Originally Posted by ChuckDriver View Post
Cool build!
Thanks!
Old 03-06-2017, 10:08 AM   #88
NickL
Cab at the blasters
Made some boxing plates from cardboard and had my local machine shop draw them up and cut them on the plasma table. Welding these in soon.
Picking the cab up
Back on the frame for a final test fit now that the parking brake is removed. Then braced before panel replacement
MMW notches tie rods installed
Can finally steer this thing in one piece
Thats it for now. My buddy is making great progress on the cab panel replacements. Ill have some photos soon.
Old 03-06-2017, 10:37 AM   #89
reaper71
reaper71's Avatar
Looking good, Any plans for the cover on the intake?
Meaning smoothing it out etc..
Mark.
reaper71 is offline   Reply With Quote
Old 03-06-2017, 01:09 PM   #90
NickL
Mark.
Nope, just leaving it. Im more for the OEM styling of it.
Old 03-07-2017, 07:39 AM   #91
gigamanx
How far down did you strip the cab before blasting? I think mine will need it but i don't know how much I'm supposed to take off. Do they primer after for you to stop flash rust?
Old 03-14-2017, 09:57 PM   #92
NickL
Completely stripped the interior and dash of everything. All glass. Doors off. I only had the interior, firewall, and bottom blasted as I'm keeping the patina. And yes, it was primed after. The metal work is happening currently and will be primed again once complete.
Old 03-14-2017, 11:05 PM   #93
84blaze
Cool idea on blasting just the interior.
Cant wait for more progress!
Old 03-16-2017, 10:19 AM   #94
gigamanx
Thanks for the response, that's a huge help.
Old 03-16-2017, 03:52 PM   #95
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks killer man, keep it up!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 03-16-2017, 04:29 PM   #96
Dan in Pasadena
Dan in Pasadena's Avatar
I'm not a patina guy but I LIKE your truck. My Dad had two AD trucks when I was a kid. One was an early truck with true door handles that turn down. It was light green with primered fenders. The other was a later one that was the same Forrest green yours is but it was IMMACULATE....so he sold it because he was a brick mason and didn't want it to get b!tched up. This was the early 60's so the truck wasn't that old.
I'd love to have your truck when it's complete.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-19-2017, 08:25 PM   #97
NickL
No problem!
Thank you!
Awesome story. I honestly have no idea how long i'll keep the truck once its complete. I know it will eventually be for sale, just depends on how much I enjoy it once its done. I have way too many toys and have been thinking about going back to school and sadly this one would be the one to fund that. We'll see.
Some more progress.
Old 03-20-2017, 11:32 PM   #98
big_moss
big_moss's Avatar
Looking good man
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 03-28-2017, 12:50 PM   #99
STOCKISH
STOCKISH's Avatar
Nice progress man. Floors looking good
--Josh
Old 03-30-2017, 12:44 PM   #100
NickL
More repairs
New inner cab corners and rear section of the floor. Both sides of the floor installed/inner cowls.
My buddy says the cab will be primed and ready Saturday so thats the plan for pickup. I am not having him replicate the patina on the new panels YET because the cab/wheels/inner fenders as well as other bits and pieces will all be traveling back to him for paintwork anyways.
I still need to burn in the boxing plates and then I'm ready for the frame to be blasted and painted. Really from there, its all downhill assembly.
