Old 11-28-2014, 07:13 PM   #1
2tontruck
Vintage Air bracket question Alan Grove 142R
Getting my parts list together for the next LS swap I will be doing in the 72 Suburban and I would like to keep the a/c compressor down low and tucked. I will be using the Sanden compressor and I am trying to see if anybody has pictures or can tell me if the Alan Grove lower truck bracket (142R) works. Any help would be appreciated.
2tontruck is offline   Reply With Quote
Old 12-06-2014, 07:50 PM   #2
conman585
conman585's Avatar
Re: Vintage Air bracket question Alan Grove 142R
I've also been curious about this. What's their return policy?
conman585 is offline   Reply With Quote
Old 12-07-2014, 11:59 PM   #3
808turbo
It fits but, it's tight. Depending on your adapter plate and motor mounts, you need to make sure it won't hit the back of the compressor. These pics are from Alan Grove. I'll try to get pics later from my truck. You also need to order the right offset mount to line up with the crank pulley.
http://s1353.photobucket.com/user/80...72c43.jpg.html
http://s1353.photobucket.com/user/80...efb77.jpg.html
808turbo is offline   Reply With Quote
Old 12-08-2014, 10:45 PM   #4
808turbo
You can see how tight it is, but it fits.
http://i1353.photobucket.com/albums/...psfe0cd84c.jpg
http://i1353.photobucket.com/albums/...psbaf25b5e.jpg
Old 12-09-2014, 10:06 AM   #5
69trk
69trk's Avatar
will this bracket work with the dirty dingo sliders?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-09-2014, 11:20 AM   #6
808turbo
I would think it would, I'm using the factory stands and adapter plates that put mounts a little forward.
Old 01-26-2017, 03:27 PM   #7
jessemthompson
Reviving an old thread. How did things work out with your lines clearing?
jessemthompson is offline   Reply With Quote
