01-23-2017, 11:42 PM | #1 |
Buried Power steering cap?
Power steering pump on drivers side is just underneath bottom bracket for alternator.I can loosen the cap ,but cant remove?? is power steering belt too tight,or should I get shorty power steering pump.Any Ideas??
01-23-2017, 11:50 PM | #2 |
Re: Buried Power steering cap?
Engine? Pic?
01-23-2017, 11:58 PM | #3 |
Sorry,the weathers bad right now,I'll try to post ,soon
01-24-2017, 12:49 AM | #4 |
GM Addicted
Have same problem on a truck as well. Power steering pump is mounted at lowest mount, LWP setup with alternator on drivers side using billet specialties mounts. There fix for issue is a type II power steering pump with remote reservoir. Kit with hoses is around 350. As long as it doesn't develop any leaks should be fine for now.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-24-2017, 01:48 AM | #5 |
Scrapper 1
I see aftermarket problems that add more problems down the road.I've seen custom car's and trucks after they are built and not driven anymore.They seem to have alol them custom parts thrown away do to pitting or they warp or people tighten the brackets to tight.Most guys love seeing factory steel brackets now days.That's where the real money lies
01-24-2017, 09:36 AM | #6 |
Old member
The factory brackets for this setup also make it hard to get the power steering cap out. Mine just does clear the alternator bracket.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-24-2017, 12:20 PM | #7 |
all stock,make me thing wrong belt
01-24-2017, 12:43 PM | #8 |
I have the same issue...when I want to check the PS fluid I loosen and move the ps pump.
1970 C10 Short Stepper with 71/72 front clip. |
01-24-2017, 01:50 PM | #9 |
Bugz, can you explain that temp gauge setup in your photo ? I am interested in installing one also, thanks
71 C-20 07 Magnum RT AWD |
01-24-2017, 01:58 PM | #10 |
GM Addicted
That's an oil pressure gauage
01-24-2017, 02:14 PM | #11 |
Old member
Factory brackets on a 305 that was once in my 71.
01-24-2017, 02:29 PM | #12 |
Which motors have an oil galley plug up front, only certain years, or smallblock only, or ??? I've seen that plug a few times but never knew when to expect it or not.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-24-2017, 02:59 PM | #13 | |
Old member
I think most chevy small blocks have them. I have know to be wrong though! My 305 did but I had my oil gauge hooked to it.
01-24-2017, 03:14 PM | #14 |
As 54Caddy noted, it is an oil pressure guage. The hole was probably originally meant for a sending unit of some type. I have an oil pressure guage on my dash cluster, but I was spending a lot of time under the hood and a pressure guage plugged in there seemed to be a good idea. It's a 1970 307 SB.
01-24-2017, 07:00 PM | #15 |
They both look like March Belt Drive systems. Part# 20113 P/S mount turns the pump inward so it is easier to get to, but it is for the SWP.
http://marchperformance.com/chevy/ch...ater-pump.html |
01-25-2017, 01:42 AM | #16 |
Regarding the pic in post 11, GM parts but not arranged as GM would on an engine..
That seems to be a short water pump and PS bracket setup made for an early engine w/ heads lacking mount holes in the end. The alt bracket mounts to the end of the head, so the brackets for PS pump and alt are from different years. The pics in posts 4 and 8 both include aftermarket or homemade brackets. The OP would need to post pics for someone to decipher what's there, but chances are its pretty much like the other pics, and not the way any year was originally set up. |
01-25-2017, 02:45 AM | #17 |
01-25-2017, 07:30 AM | #18 | |
Old member
I don't understand the comment, chevy parts but not the way they would do it. This is the only way to do the parts. The bolt holes only match up if done this way. Here is my 64 Impala ss that I installed a late model 98amp alternator with a 71 C 10 bracket. It's the same way. Yes I took them back off and cleaned them up and painted them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-25-2017 at 07:45 AM. |
01-25-2017, 08:23 AM | #19 | |
Edit...with further review ...I believe that kit is for serpentine system. Depending how far in the PS pump is tilted inward, the belt going to the alternator could rub against the PS pump snout (between the pump housing and the pulley)
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 01-25-2017 at 08:43 AM. |
01-26-2017, 10:46 AM | #20 |
It has to be too long of a belt or mismatched parts. On a proper original set-up the cap is in a tight spot. But GM certainly designed them so we could check and fill our power steering pumps. I've never had an issue...other than it's tight getting the cap on & off, they are hard to look down into, and a royal pain to fill. They're also a PIA to adjust if you ask me. The P/S pumps are tucked quite tightly down there in it's own little nook. Call me lazy, but I've gone with the "don't see no leakin' don't need no checkin'" technique for years. Never burned a pump up. GM made some great stuff.
01-26-2017, 12:05 PM | #21 | |
01-29-2017, 01:21 PM | #22 |
The picture that andy posted was pretty close to mine.
With a shorter belt and a modified bottom bracket the top comes off now. A local shop cut a semi circle out of it about the size of a silver dollar. Thanks guys! |
